Help! How do you remove fender on a 2001 durango
Old Oct 4, 2010 | 09:20 PM
wearling's Avatar
wearling
Default Help! How do you remove fender on a 2001 durango
Help! I have removed all the bolts to a right fender on a 2001 dodge durango. I also removed the fender flare, but it still won't budge. Help!
Old Oct 4, 2010 | 11:10 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
REMOVAL
Disconnect battery negative cable.
Raise and support the vehicle.
Remove right front wheel.
Remove wheel opening molding.
Remove wheelhouse liner.
Remove right headlamp module.
Remove air cleaner element housing.
Remove powertrain control module.
Disengage clips attaching wire harnesses to inner fender and wheelhouse.
Remove bolt attaching fender to lower rocker panel.
Remove bolts attaching fender to lower radiator closure panel (FRONT FENDER).
Remove bolts attaching fender to hood hinge support bracket.
Remove bolts attaching fender to upper cowl.
Remove bolts attaching fender to upper radiator closure panel.
Separate fender and wheelhouse from vehicle.
Old Oct 5, 2010 | 09:25 AM
Dans01Durango's Avatar
Dans01Durango
Or... run a chain from the fender to a staionary object, like a really big rock!
Put vehicle in reverse
Stomp on gas pedal
Rip fender off!
Old Oct 5, 2010 | 09:59 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
DAN!!!!! stop causing trouble, hes gotta be trying to remove it without doing any extra damage
Old Oct 6, 2010 | 08:41 AM
wearling's Avatar
wearling
Default Got it off!
Thanks for your help. I got it. Yipee!!
Old Oct 6, 2010 | 10:06 AM
Dans01Durango
Sowwy...
Old Oct 6, 2010 | 02:37 PM
hydrashocker's Avatar
hydrashocker
Lmao!
Old Jun 29, 2011 | 06:12 PM
02Rango's Avatar
02Rango
about to do this too but i have one quick question before i get started
should i paint it before i put it on? prime it atleast? it needs to go from red to silver and i was planning on doing it myself somehow ofcourse
Old Jun 29, 2011 | 06:24 PM
shrpshtr325
THE ULTI-MOD
i would paint the fender before installing it unless you plan to have the entire truck painted, then i would paint the engine side before putting it on bc that side is very difficult to do once installed.
Old Jun 30, 2011 | 02:12 PM
topdogcustoms's Avatar
topdogcustoms
+1 Shrp
