Removing catalytic converter on 98?
Old Dec 13, 2010 | 10:47 PM
Jordan91ulbrich's Avatar
Jordan91ulbrich
Default Removing catalytic converter on 98?
Has anyone Removed their catalytic converter on their Durango. I would like to remove mine but i am scared it will run like ****. Anyone have problems or here of any problems. Its a 1998 5.2 and has almost 180,000. stock motor and trans.
Old Dec 14, 2010 | 12:39 AM
IndyDurango's Avatar
IndyDurango
Not only is it illegal, there is no valid or performance reason to run without the Cat on the 98 D. It will run worse.
IndyDurango
Old Dec 14, 2010 | 02:59 AM
Biff85ta's Avatar
Biff85ta
It will not run worse. It will however set a code from the rear O2's but those are there to monitor the cat the one that controls air fuel mix is upstream of the cat.
Old Dec 14, 2010 | 07:11 AM
Duranged408's Avatar
Duranged408
Agree with Indy, no valid reason to remove. Now if it was clogged i could understand, but pointless/annoying/shadetree/redneck not to run one. If your looking for tone, just get a new catback, no performance gain will be seen removing/replacing the cat. It may not run horrible but it will run worse...
Old Dec 14, 2010 | 07:34 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
indy and duranged are correct, the trucks will not run correctly, will throw codes, and will (best of all, at least for the cops) it is illegal. (where i am if your exhaust sound is too loud they are allowed to 'inspect' it on the side of the road, if your cat is missing you get a ticket)
Old Dec 14, 2010 | 09:23 AM
Jordan91ulbrich
ok. Well to the best of my knowledge with out inspecting my cat is clogged. I have little to no throttle response and if i put my ear by my cat it sounds like a leaky air compresses. But their is no leak in my exhaust. i would Probably be removing the cat and taking the **** out then re-installing it. And for the cops i already got a ticket for having it strait piped form the Cat back so i am not worried about paying tickets because in Michigan its just a Fix It Ticket.
Old Dec 14, 2010 | 09:27 AM
Dans01Durango's Avatar
Dans01Durango
+4 Leave the cat in place. If you really want to bypass it, there's a product out there that can do that. Google something like catalytic bypass valve or something like that. Otherwise, no gain for removing the cat and like shrps said, the extra loud exhaust gives cops the justification to pull you over and possibly give you a ticket, fine and or impound your D. Don't know how old you are but please heed our advice, we've all been through this. Louder=bad azz. No, louder= more scrutiny from Johhny Law. It's up to you to use the advise given.
Old Dec 14, 2010 | 04:21 PM
hydrashocker's Avatar
hydrashocker
Leave the CAT. If you want more out of it then replace it with a Hi-Flow design and be done with it.
Old Dec 14, 2010 | 05:00 PM
WhiteWidow00's Avatar
WhiteWidow00
What exactly are you tryin to achieve by removing it?!
Old Dec 14, 2010 | 07:36 PM
Jordan91ulbrich
Idk. Maybe more throttle response. But like everyone says it will not help. And yes i am young so i like my sh*t loud. Sounds good right know. I have the cat with a Strait threw DynoMax.
