Aftermarket Hoods
I know from what I've seen from Indy, Moore makes an awesome Ram Air hood.
http://www.fiberglass-hoods.com/
go onto summitracing.com , type in your trucks info, and look under the "hoods" section and there will be a good list of what you can get.
My personal favorite is the cuda style hood, because its subtle but you can see it there if ya look, its fiberglass, and its also makes for a ram air system. BUT its also pretty expensive to, will set you back bout 900 for just the hood.
also keep your eye out for hoods on other dodge fourms to, good luck.
Trending Topics
Traditionally there is modification that is a transfer cable or bar that extends the latch mechanism downward to the bottom of the grille/top of the bumper so you can reach it. There would be no getting to the stock location of course since the grille openings are "sealed".
HOWEVER, one of my 1000 modifications to my Durango include the relocation of my grille. That was done this year and sometime after the hood was installed back in 2008. I just use the stocker latching now. See below.
IndyDurango
IndyDurango
