Random Misfires?
Old Dec 26, 2010 | 12:35 PM
lucky76jd's Avatar
lucky76jd
Default Random Misfires?
Its me again, with another question. I am getting misfires on Cyl 1, 4, and 8. I am also getting injector circuit malfunctions on cyl 1, 3, and 4. I did ohms tests and 12V tests on all the injectors and they seem to be functioning correctly. I am now thinking the codes could be due to the camshaft position sensor. Any thoughts?
Jay
Old Dec 27, 2010 | 12:12 AM
WhiteWidow00's Avatar
WhiteWidow00
As far as the misfires, I would check the spark plugs in those cylinders and if they're looking fouled I would replace all 8 (champion copper). As far as the injector malfunction I would guess since they're reading alright it could be a short in the wires, or a potential bad PCM.
Old Dec 27, 2010 | 01:40 AM
hydrashocker's Avatar
hydrashocker
Replace the plugs first and foremost, then move to the next option. Gap the OEM Champion Copper's at .040 before installation.
Old Dec 27, 2010 | 01:52 AM
lucky76jd's Avatar
lucky76jd
I very recently replaced the plugs with Bosch platinum 2's. Really dont wanna replace them again. U dont think it could be the cam pos senser?
Old Dec 27, 2010 | 08:34 AM
WhiteWidow00
Take those platinum plugs out asap! That is most likely where your problem was erected! You never put platinum in these rigs I don't care what the auto parts guys say. I've been working at my shop for 3 years now and we haven't had one problem due to spark plugs because of the fact we use what the OEM specs call for. For these particular rigs the temperature plugs it calls for is Champion Copper (el cheapo plugs).
Champion Iridium is also fine but never never use platinum. I would get those out asap like I said.
Typically if it was the cam sensor it would spit to you a check engine light and a code such as P0340.
Old Dec 27, 2010 | 09:12 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
those platinum plugs are most likely your problem, these trucks dont like platinum plugs and you should NEVER put them in it, take em out and put cheapo champion copper cores in there
Old Dec 27, 2010 | 06:20 PM
hydrashocker
Take those POS's out of the truck and take em back tell the Auto Parts counter personel they they don't work and exchange them for the cheap Champion Copper plugs. They are OEM and they work.
Old Dec 27, 2010 | 10:02 PM
lucky76jd's Avatar
lucky76jd
WOW, Damn I guess I wasted my money on them plugs then. I am gonna swap out thoes plugs asap. Thanks a lot.
Old Dec 28, 2010 | 03:24 PM
a57chevy43's Avatar
a57chevy43
Typically when a cam sensor fails it fails all together. It wont send intermittent signals to the computer. and If it does the computer will pick it up and shut the system down. Cause the computer has to know exactly where the engine is in its cycle at all times to function. I would suggest especial with recent experience that is something simple like plugs or worse case some shorted wires to the coil packs.
Old Dec 28, 2010 | 05:14 PM
WhiteWidow00
57chevy, no coil packs on the 5.9. His info states he has a 2000 r/t which only has the 5.9 engine. So spark plugs or plug wires only.
Edit: Also, come to think of it the Bosch Platinum+2 have a non adjustable gap so what they come as is what you're stuck with. For anybody reading this in the future, never use those POS's!!
