getting warm heat when on full blast
Old 03-01-2011, 03:58 PM
bblok572cid's Avatar
bblok572cid
bblok572cid is offline
Default getting warm heat when on full blast
anybody know what would cause my 4.7L 2000 durango slt to not get hot air? i get warm heat with cold air coming through the vents too i freeze in the winter any help would be great!!
Old 03-01-2011, 04:01 PM
coreybv's Avatar
coreybv
coreybv is offline
Has there ever been any stop leak used in the radiator?
Old 03-01-2011, 04:10 PM
WhiteWidow00's Avatar
WhiteWidow00
WhiteWidow00 is offline
Sounds like a blend door problem.
Old 03-01-2011, 04:32 PM
bblok572cid
not sure about the stop leak i bought it used changed thermostat and still no heat
bblok572cid
where is the blend door??
Old 03-01-2011, 04:38 PM
WhiteWidow00
https://dodgeforum.com/forum/attachm...nditioning.pdf
Here is a manual for heating and A/C for your vehicle it should help you org everything. Refer to page 57 & 58 for the blend door.
Old 03-01-2011, 08:18 PM
bblok572cid
thanks for the help
Old 03-01-2011, 09:48 PM
SumAmerican's Avatar
SumAmerican
SumAmerican is offline
heater core could be getting old and clogged too.. That might be easier to check then the blend door.. (you might be able to hear the blend door move when you change the temp dealy... i know i can hear it clear as day in my neon)
Old 03-01-2011, 09:53 PM
MN_DeeDee's Avatar
MN_DeeDee
MN_DeeDee is offline
This may be totally wrong and unrelated, but I once had an old junker that lost coolant. I never figured out where it leaked and to be honest, I didn't want to put money into the car. But the first sign that the coolant was low was that the heater stopped working. The car never overheated because I kept topping it up, but the heater thing was a good sign for me.
Old 03-01-2011, 11:15 PM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
Blow out the heater core using a garden hose and the house spicket. Most likely your heater core is plugged up.
Quick Reply: getting warm heat when on full blast
