Dash Lights and Blinkers
Howdy - 200 Durango, 4.7 4X4. Great truck, but all of a sudden, when I turn on the left blinker (head lights off), the dash lights all flash in opposite sequence. Also, when the headlights are on, I have no left blinker. ALSO, the left rear and front right marker lamps are burning much brighter than the others. I already replace all of the rear bulbs. Any Ideas?
Sorry for the multi-posting, but something came to mind. Last week, a rear door actuator went out on me, and I unplugged the power harness, thinking it would just shut it off. I instantly blew a taillight fuse, so I replaced the fuse and re-plugged the actuator. Does doing this require re-initializing the CTM or something else? If so, can anyone other than the dealer do this? Can I just unhook the battery and hard-boot the entire system?
Thanks!!
Thanks!!
Tried the hard reset...no difference. Still flashes the dash lights when the headlights are off and the left blinker is turned on (both rear lights flash, but just the front left flashes). The right blinker works fine...front and rear lights work as expected When the headlights are on, and the left blinker is engaged, nothing happens...just the left blinker arrow burns continuously and no flash, front or back...again, the right side works fine. Any ideas??
Trending Topics
I still have the problem...left blinker causes the dash lights to flash, etc.
I replaced all six of the bulbs in the rear, and cleaned all of the contacts, and verified that all six are burning in the front, although one bulb burns brighter in the rear left, and the front right...?
Today I noticed that my hazards work fine when the headlights are off, but as soon as I turn the lights on, the hazards stop working? ANy ides? Is the flasher dying, perhaps? I may replace it, just to see...it looks pretty easy to get to.
I have also popped the trailer fuse, thinking that if it was a wiring issue at the hitch, this would solve it. No effect...the problem remains the same, so I'm thinking it is NOT the trailer wiring.
urgh
urgh
