A/C Compressor Indicator
Old 04-02-2011, 04:46 PM
Groggy's Avatar
Groggy
Groggy is offline
Default A/C Compressor Indicator
I upgraded to my Durango to have the power and comfort level I wanted to have even while towing. I was frustrated that I could not tell when the A/C Compressor was running. While normally this would not be an issue, I wanted to make sure that if I turned off my A/C, it was really off. I spliced into the clutch power lines and ran them into the cab, opened up the selector switch assembly and added a resistor and a bright green led to turn on when the clutch received 12v to turn on. I took a video of the result. I am pleased with the outcome and learned that when the selector is on the third option for panel/floor, that the A/C is still "ON". This is why when I turned the selector from Max Air or Air to Panel and Floor that the compressor seamed to keep running... because it was!
In the video I start'r up, turn on the lights, crank up the brightness, drop it into drive and run through the selector switch to show the additional light when the compressor turns on. If I leave it alone (the selector switch) on a setting that runs the A/C, it will turn off, then back on as the pressure cycles.
http://www.youtube.com/watch?v=GH9HDEwYiWk
Old 04-02-2011, 05:12 PM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
i like that idea
Old 04-03-2011, 12:37 AM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
HELL YA, I,VE BEEN WONDERING ABOUT THAT VERY F**KIN THING!!!!!!!!
I have been here for years!!!!!, and even knowing that I thought the very same thing (with backing from the service manual), you just proved my very freakin thoughts! I have always'ed thought that the A/C compressor was moving even though I was told it wasn't supposed to be. Even though people have told me to keep it in other positions, I've kept mine in floor or panel only. All I can say is WOW!
BTW, you are a hairy SOB just like me........LOL
Old 04-03-2011, 01:05 AM
IndyDurango's Avatar
IndyDurango
IndyDurango is offline
AC is the THREE spots closest to the LEFT... even though only TWO of them have snowflakes on the switch showing they are AC settings.
See... in EARLY 1998 Dodge had the snow flakes in all 3 spots. For some reason, later in 98 and on from there, the snow flake indicator was only on the last 2 spots even though all 3 were still AC.
The 3 snow flake indicators are rare. I have one in the garage waiting for some spare time to add it to my 2 flake indicator "Just Because" and to be probably the only 2000 D in the world with all three snowflakes.
The AC compressor DOES cycle in the Defrost settings as well. No AC, but the compressor will cycle.
IndyDurango
Old 04-03-2011, 02:47 AM
Groggy's Avatar
Groggy
Groggy is offline
Hydra,
I might be the tallest EWOK Ever! But at least I know when my A/C compressor is running... LOL
Indy,
I kept being told by people that I have had in my D that the A/C was not running in Panel/Floor, but there you go. I think that If I was to have purchased a new Durango in '00 that I would have sprang for the $0.45 option for the third snowflake!
Old 04-03-2011, 03:11 AM
IndyDurango
LOL. Indeed!!
They just stopped putting the snowflake indicator on the panel. I am sure it was a mistake however they never went back and corrected it.
Now you know!
BTW, what is that vibrating noise in the video?
IndyD
Old 04-03-2011, 03:24 AM
MAGIC84's Avatar
MAGIC84
MAGIC84 is offline
Groggy........It was probably a 0.45 cent option for them.......For the Consumer it probably would be more like a $45.00 option....LOL!!
I always heard that the Compressor cycles on defrost mode, provides supplemental air to help defrost the windshields faster and keep them cleaner.
Now that we are transitioning from Winter to Spring sounds like we might getting more VENT/A/C posts. Probably just people ops checking and letting us know how they work.
Old 04-03-2011, 11:49 AM
Groggy's Avatar
Groggy
Groggy is offline
Indy,
I honestly did not notice that! Now I gotta go figure out what the noise is... I re-did the video with the camera in the same position, mounted to my Gorilla pod and clinging to the top of the passenger seat. The noise was there when the D was running. I moved the camera to be sitting on the seat cushion of the passenger seat and the noise went away. I guess the seat back of the passenger seat is rattling. I can't here it without the camera, so I guess it's OK.
Where did you come by the 3 snowflake indicator? Is it something you picked up while at a wrecking yard?
Old 04-03-2011, 01:04 PM
WhiteWidow00's Avatar
WhiteWidow00
WhiteWidow00 is offline
That's pretty cool not gonna lie. I think once I get around to buying a new A/C compressor to put in (have a bypass pulley in there for now since old one seized up) I will be doing this because I really like that idea. Well done!
Old 04-03-2011, 04:28 PM
IndyDurango
Yes. Pick-a-Part in Indianapolis.
IndyD
Quick Reply: A/C Compressor Indicator
