Loud Fuel Pump?
Old May 13, 2011 | 07:06 AM
  #21
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
can you hear it from inside while the engine is on? no, then your fine
Old May 14, 2011 | 09:39 PM
  #22
99_dingo's Avatar
99_dingo
if there isnt anything on like radio heater etc windows up i can
Old May 16, 2011 | 06:34 PM
  #23
rob[GL]'s Avatar
rob[GL]
Funny this thread popped up again... My fuel pump has gotten slightly quieter as of late. I'm not sure whether to be worried or not.
Either it was loud because some grime got in there and it was working hard, and now it's clean, or... It was whining because it really is dying, and now it's quieter because it's aboue to give up all together.
I'll let you guys know.
Old May 16, 2011 | 11:43 PM
  #24
barthel's Avatar
barthel
This^
My Mustang did the same thing. Pump was perfectly quiet, then god horribly loud. I changed it before it went Tango Uniform.
It's on it's way out, change it ASAP before it strands you somewhere.
Old May 17, 2011 | 02:46 PM
  #25
99_dingo's Avatar
99_dingo
ok as far as mine is it sounds the same as if it has when i got it yesterday i left it sit and run for half an hour at idle then took it for a hell ride ( running it hard ) and it performed just as it always did brought it home shut it off first bump of the key it started i can leave it sit for days and almost always 1st or 2nd bump of the key it starts
Old Jun 12, 2011 | 02:26 PM
  #26
99_dingo's Avatar
99_dingo
well i finally changed my fuel pump 239 freakin dollars it wasnt as bad as i expected then i come to find out my tank straps where bad after buyin the pump and busting a brake line i ended up gone and getting 2 1000lbs ratchet straps i know not oem but times are hard and i gotta spend money wisely and believe it or not my pump was still factory and it had 168k on!
