change motor from a 4.7 to 318
Old Apr 28, 2011 | 09:30 PM
greg cummings's Avatar
greg cummings
Default change motor from a 4.7 to 318
i am a new member and wandering ihave a2000 durango and motor needs rebuilt or replaced and 4.7 is expensive and 318 is more comon so will it bolt to tranny and wath about wireing harnes and computer i am very mechanical this is my first dodge
Old Apr 28, 2011 | 09:33 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
no it wont bolt up to the same transmission
in order to do the swap from a 4.7 to the 5.2 you will need (at a minimum)
1)engine
2)transmission
3)wire harness
4)computer
5)some say motor mounts, i cannot confirm or deny this one
Old Apr 28, 2011 | 10:02 PM
WhiteWidow00's Avatar
WhiteWidow00
Like shrp said, you will need basically everything to start from scratch because nothing will line up and more than likely you will spend more time and money on the replacement than if you would on doing an overhaul, that is unless you get a ridiculously good deal on the 318.
The tranny will not bolt up and in fact you will need a new transmission because the 44re was backed behind the 318 and not the 545rfe. Also, I'm not sure how correct that statement is that the 318 is more common, because honestly I've seen more 4.7s and 5.9s than I've seen the 5.2 motor. I think in all my years I've worked on 2 or 3 Durangos where the 5.2 was under the hood.
Also, for the record the grammar police has pulled you over...
It should read...
I am a new member and wandering, I have a 2000 durango and motor needs rebuilt or replaced, and 4.7 is expensive and 318 is more common so, will it bolt to tranny and what about wiring harness and computer? I am very mechanical, this is my first dodge.
Old Apr 28, 2011 | 10:34 PM
Groggy's Avatar
Groggy
WW,
Is he wandering or wondering...
Greg,
That sounds like one hell of a project, I think I would buy a different D before I went through all of that!
Old Apr 28, 2011 | 10:37 PM
WhiteWidow00
Aha indeed you are correct that he is wondering! Good catch.
Old Apr 29, 2011 | 07:23 AM
samnbensdad's Avatar
samnbensdad
Brutal...
Old Apr 29, 2011 | 09:19 AM
shrpshtr325
THE ULTI-MOD
i take a guess we wont be hearing back from him, good job widow . . .(yes, sarcasm)
Old Apr 29, 2011 | 10:26 PM
greg cummings
1)engine
2)transmission
3)wire harness
4)computer
Thanks so much for your help really appreciated..
Old Apr 29, 2011 | 10:31 PM
greg cummings
okay since you and your sarcasm is sooo interested in how i typed this..HERE IT is just for you..I was tired and seein kinda double we were curious on how OR wat to do with our dodge..I THOUGHT THIS SITE WAS HERE TO HELP!!! NOT JUDGE..SO YES YOU ARE HEARING FROM ME..SO IF YOU ARE JUST HERE TO PUT PPL DOWN THEN I SUGGEST YOU GO GET ON FACEBOOK OR MYSPACE!! CAUSE THATS WHERE THE GOSSIP BITCHS ARE!!
Old Apr 29, 2011 | 10:38 PM
greg cummings
It should read...
OK WELL thanks for the info i did get a really great deal today on a 318 and tranny..and like i told the some of other ones on here was really tired from working all day and i am not really used to this computer thing..JUST wanted some info on how and wat to do..didnt know ppl would have something to say about how i type lol. i guess you all understood wat i was asking..geez
