DIY: Adding a overhead console w/ temperature and compass (Durango Edition)
Old Mar 14, 2015 | 01:44 PM
  #71
that_guy's Avatar
that_guy
Might be the ccd bus wire. Double check the diagrams in the FSMs (found in the DIY section) to be sure though.
Old Mar 14, 2015 | 02:37 PM
  #72
flyingvfreak's Avatar
flyingvfreak
Thanks , for quick reply. I just noticed the auto dim mirror that I'm also adding has blue/white,blk,and purple/blk.
Old Mar 14, 2015 | 04:32 PM
  #73
that_guy's Avatar
that_guy
It might be for those. Of the wires that go to the mirror, one is 12v+, one is ground, and one is a reverse signal to undim the mirror when backing up.
Old Mar 15, 2015 | 07:52 PM
  #74
Old_School's Avatar
Old_School
Blue/white = 12v
Black= Ground
Purple/black= reverse signal.
Old Apr 3, 2015 | 01:20 AM
  #75
flyingvfreak
thanks for the input, ive been busy at work, I understand the purple and whit but were can i Tap into on the Fuse block or any were else??
Old Apr 6, 2015 | 08:45 PM
  #76
Old_School's Avatar
Old_School
for the mirror or power for the cluster?
Old Apr 7, 2015 | 09:20 AM
  #77
flyingvfreak
For the mirror. I got everything hooked up and works great except that purple mirror wire
No idea where to hook it up too
Old Apr 7, 2015 | 04:15 PM
  #78
Old_School's Avatar
Old_School
No idea were to hook it up too
IIRC, i tapped the same purple wire in the PDC in the connector on the right side.
Old Apr 27, 2019 | 02:11 PM
  #79
Eric Wilson's Avatar
Eric Wilson
Default 02 console
I put an overhead Consol in my 01 As part of a complete interior swap swa as part of a complete interior swap it was a skinnier consul with the home link in the back trip computer upfront and a sunglass holder in the middle everything worked great! Then stupid me couldn’t leave well enough alone I found a consul from an 02 that was wider and have the home link up front in the truck computer and a large compartment in the back so I re-cut my headliner and installed it this was a used consul now everything works fine except for the temperature I have done the system diagnostic and it says Pass. But it just shows two lines in the temp area... any ideas? I’m lost on this one!
Old Apr 27, 2019 | 06:55 PM
  #80
Not getting a signal from the ambient temp sensor??
