rear differetial?
Old 07-03-2011, 03:54 PM
noman's Avatar
noman
noman is offline
Default rear differetial?
I was wondering if I had limited slip differential. So I checked it by turning the wheels. The tires started to spin in opposite directions then stopped so only on tire was spinning. Is that normal?
Everything I read about checking differentials limited slip spins the same direction and open spins in opposite. Is there something wrong with mine?
Old 07-03-2011, 03:56 PM
topdogcustoms's Avatar
topdogcustoms
topdogcustoms is offline
are you sure you have a limited slip differential
Old 07-03-2011, 04:09 PM
noman's Avatar
noman
noman is offline
I don't know if I have limited slip. I couldn't find anything on the sticker in the glove box. So I decided to raise rear end and check.
Old 07-03-2011, 04:20 PM
topdogcustoms
Go to this site and enter your vin# it will tell you if you have one or not
http://www.compnine.com/vid.php?vin=1b4hs28n11f505789
Old 07-03-2011, 04:51 PM
noman's Avatar
noman
noman is offline
It doesn't say anything about limited slip. My biggest question is why the wheels started to spin in opposite direction the stopped so only one wheel was spinning?
Old 07-03-2011, 09:32 PM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
was anything touching the wheel that stopped?
Old 07-03-2011, 09:48 PM
srch4me's Avatar
srch4me
srch4me is offline
post the build sheet maybe... and if it spins in different directions then the differential is open or limited slip is shot...
Old 07-04-2011, 10:17 AM
noman's Avatar
noman
noman is offline
I can't figure out how to post the build sheet. It says 3.55 gear ratio, Corporate 9.25 LD rear axle. It doesn't say anything on the sheet about limited slip.
Nothing was touching the other wheel. They were both off the ground.
Old 07-04-2011, 10:24 AM
Old_School's Avatar
Old_School
Old_School is offline
you have a 9.25" ring gear , 3.55 gear ratio and the "LD" stands for light duty. it is NOT a limited slip.
Old 07-04-2011, 11:07 AM
noman's Avatar
noman
noman is offline
I kinda figured it wasn't limited. My biggest concern is why does the wheels start to turn in opposite directions then stop. Everything I've read and the videos I've watched they keep turning in opposite directions.
Quick Reply: rear differetial?
