2000 running rough and pulsing
My 2000 with the 4.7 and all time 4WD has been running rough and after driving for 30 minutes or so when on the highway or accelerating my RPM's will pulse my 200-300.
I hope it isn't the fuel filter but I think that would be a more consistent issue but I ran some B12 through a 3/4 filled tank and it didn't see to help.
Air filter is good as well.
Could it be something with the spark plugs, wires, distributors?
+1 on the TPS also, could be a dirty throttle body or IAC or a combo of both!
I have also seen a bad battery causing low voltage and making the TPS not act right... if i where you i would clean the throttle body, IAC and if that does not help have the battery load tested.
Thanks for all the quickt replies!
So I don't drive the Durango a lot any more and finally got around to fixing today. Interestingly enough, I was shipped the wrong TPS and didn't realize it until I had the old one out. The old had tons of build up on it so I went ahead and cleaned it off with a dry cloth then a dash of WD-40 and put it back in.
The Durango went from 11.3 MPH to 13.8 and is running better than it has in years.
So, if you have the pulsing issue at all speeds and it runs rough, try cleaning the TPS before replacing it as you may end up with quick and free fix.
Trending Topics
