Fan/clutch fan
Old Aug 17, 2011 | 10:14 PM
ramhead101's Avatar
ramhead101
Default Fan/clutch fan
Hey guys quick question my friend was able to hook up a flex fan to his bronco without the clutch so it spins at whatever speed the engine is spinning at. And it really sounds nice would i be able to do this to a 318?
Old Aug 17, 2011 | 10:43 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
im sure you could find the parts to do it, but that would be one hell of a drag on the engine to run the fan at full engine speed all the time.
Old Aug 17, 2011 | 11:13 PM
topdogcustoms's Avatar
topdogcustoms
+1 shrp
i guess you like buying gas lol
Old Aug 17, 2011 | 11:24 PM
adukart's Avatar
adukart
+2 shrps, it is a colossal waste of gas
Old Aug 17, 2011 | 11:30 PM
Rich4887's Avatar
Rich4887
Why do that when you could get a electric fan conversion kit that gets rid of the fan clutch all together.......
Old Aug 18, 2011 | 12:36 AM
ramhead101's Avatar
ramhead101
Yea im starting to lean towards the electric fan
Old Aug 18, 2011 | 08:20 AM
shrpshtr325
THE ULTI-MOD
the electric fan is definitely the better way to go if you dont like the clutch fan.
Old Aug 18, 2011 | 03:20 PM
Rich4887's Avatar
Rich4887
Just make sure and get a heavy duty electric fan espically if you plan on towing
Old Aug 18, 2011 | 06:08 PM
hydrashocker's Avatar
hydrashocker
Well specific type flex fans pull more air then electric and have a lot less continuous load than one would think. But I agree, a clutch will pull the most air hands down, while a full electric setup will only pull maybe 1 or 2 HP's from the load up of Amp's being used.
I used to run a flex fan on a Cobra Jet motor I had in my old Ford and it kicked *** over that particular OEM setup, but it still wasn't an electrical setup.
Old Aug 18, 2011 | 11:52 PM
ramhead101's Avatar
ramhead101
So hydrashocker what exactly do you think i should run
