Clunk clunk from fron end
Old Dec 2, 2011 | 04:47 PM
Rango02RT's Avatar
Rango02RT
Question Clunk clunk from fron end
I've got a 2002 Durango RT AWD . With a clunk clunk noise when I rh turn and go over a bump and drive from a stop but it doesn't do it all the time.. I recently had the transmission rebuilt due to the over drive bearing shattered..
Old Dec 2, 2011 | 04:58 PM
TurboStixx's Avatar
TurboStixx
Possibly something in the suspension?
Old Dec 2, 2011 | 05:35 PM
adukart's Avatar
adukart
Pull the tires off the front and check the u-joints. Also check the sway bar and any other suspension components to make sure everything is tight and in its proper place. What side of the vehicle and where does it sound like it is coming from?
Old Dec 2, 2011 | 06:00 PM
samnbensdad's Avatar
samnbensdad
Intermediate steering shaft
Old Dec 2, 2011 | 08:12 PM
that_guy's Avatar
that_guy
Wouldn't hurt to check the ball joints either
Old Dec 2, 2011 | 08:22 PM
adukart's Avatar
adukart
Basically give that front end a good inspection........
Old Dec 2, 2011 | 10:07 PM
Rango02RT's Avatar
Rango02RT
Sounds like its coming from driver side
And when I went to stop slowly it started shaking??
Old Dec 2, 2011 | 11:08 PM
TurboStixx's Avatar
TurboStixx
Yeah, that definitely sounds like something in the suspension to me. I would check the sway bar like adukart said and I would also check the ball joints like that_guy said. I was thinking ball joints earlier myself but I couldn't get that part name off the top of my head (had to wife talking to me about something useless.)
If all of that is tight, not broke, and completely greased, I would then do as samnbensdad said and check your Intermediate steering shaft. If all of that seems sound and good to go let us know, but I bet you will find it somewhere in the front suspension!
Old Dec 2, 2011 | 11:59 PM
ZCR1's Avatar
ZCR1
Use a Floor jack under the outer most part of the lower control arms to unload the ball joints and try to shake them. If you don't the torsion bars will keep a load on them and they will seem tight.
Old Dec 3, 2011 | 02:53 PM
Rango02RT's Avatar
Rango02RT
Ok took both cv axles out... driver side grease is black.. and passenger side is a greenish brown....
how do I tell if there bad?
