Some one with a 99 Please post a pic
Old Jan 4, 2012 | 06:09 PM
  #21
hydrashocker's Avatar
hydrashocker
Lucas sucks, and Fram sucks!
Get yourself a new Bosch or Puralator filter with a anti-drain valve, and a 5 quart bottle of Mobil One Fully Synthetic 10W-30 for that 5.2L engine. (I usually get the black boxed Bosch filter for $5) Remove the oil filter first then remove the oil from the pan and let her drip. Now replace the filter and add the whole 5 quart bottle you bought at Wal-Mart for about $25 bucks. Now you should be full, however you might need an extra 1/2 quart, at least I know many 5.9L's that like that extra 1/2 quart. At this point you should be full and mark your dipstick.
I like to check the oil first thing in the morning, but it is supposed to be warm I believe.
lvphotos<----If you have a leak then fix it. Durango's aren't "drippers". Dripping gaskets are because of lack of maintenance.
Old Jan 4, 2012 | 06:24 PM
  #22
TurboStixx's Avatar
TurboStixx
We will be back in the 60s this weekend, will try to get around to completely changing that oil! I have castrol now, will change it.
So you think i should go fully synthetic huh, ok!
Old Jan 4, 2012 | 06:29 PM
  #23
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
10w30 is the recommended weight of oil for the 5.2 and 5.9l engines
5w30 is the recommended weight of oil for the 4.7
Old Jan 4, 2012 | 07:55 PM
  #24
TurboStixx's Avatar
TurboStixx
That guy with the 10w40 and all that other stuff he said, he is smoking some good stuff, i only use 10w30
Old Jan 4, 2012 | 09:38 PM
  #25
adukart's Avatar
adukart
I use 5w-30, even experimented with 0w-30. They both ran good especially at -20 degrees.
Old Jan 4, 2012 | 10:02 PM
  #26
that_guy's Avatar
that_guy
all I've ever used is 10w-30, then again it wasn't really ever 20 below in Pittsburgh and it sure as hell isn't that cold in south carolina either
Old Jan 4, 2012 | 10:17 PM
  #27
TurboStixx's Avatar
TurboStixx
Yeah never gets that cold here, i could go down to 0w30 according to that chart that shows what climate should use what, though i only trust 10w30
Old Jan 4, 2012 | 10:24 PM
  #28
shrpshtr325
THE ULTI-MOD
i use 10w30 in mine however once i run through the last of what i have in the basement (iv been buying it by the case for a good price) im going to give mobile 1 0w30 a try see if i can quiet down the lash adjusters first thing in the AM
Old Jan 4, 2012 | 11:48 PM
  #29
TurboStixx's Avatar
TurboStixx
Isnt 0w30 a whole lot thinner than 10w30? Or is it a little thicker? Never actually looked at it
Old Jan 5, 2012 | 08:17 AM
  #30
adukart's Avatar
adukart
Thinner when cold, same when warm.
