1st gen durango its a 99 with 5.9 4x4
Old Jan 17, 2012 | 07:18 PM
jswank's Avatar
jswank
Default 1st gen durango its a 99 with 5.9 4x4
I went out to start my durango an it was dead.I replaced the alternator an battery.An it still wont start.I have fuel going to the plugs an as I can tell it has spark but didnt look real strong.Do you guys have any tips on what to check an I have a short some were im assuming cause left the battery in over night an it was dead today.Im getting very angry with this an I have called alot of people that I know an no one has any ideas.Hope you guys can help me out.Thanks oh an my driver side blinker blinks fast an my rear wiper wont work.
Old Jan 17, 2012 | 07:39 PM
Frozen_Joker's Avatar
Frozen_Joker
Blinker is either a bulb or a fuse. Wiper is the wiper motor. As for your start issue, does it turn over at all or try to at least? Or does it just click?
Old Jan 17, 2012 | 07:48 PM
jswank's Avatar
jswank
It turns over just wont fire.
Old Jan 17, 2012 | 08:37 PM
Frozen_Joker
Check your distributor and wires. Make sure spark is coming out of your distributor wire.
Old Jan 17, 2012 | 10:47 PM
hydrashocker's Avatar
hydrashocker
If you have fuel pressure that is under pressure (depress the valve on the drivers side), and you have some spark I would think it is a coil or wire issue.
Get the wires from the dealer, cap and rotor from you local parts store, spark plugs from the local parts store (Champion Copper gap at .040), and coil from where ever you like.
Old Jan 17, 2012 | 11:03 PM
otgarzà's Avatar
otgarzà
Yeah frozen and hydra are right...do the tune up with the champion plugs, get the cap and rotor and see if itll make a difference. The blinker is most likely the bulb or a fuse. And the wiper could be the rear wiper fuse or the motor.
Old Jan 17, 2012 | 11:09 PM
jswank's Avatar
jswank
ok will try the tune up and see if that works
Old Jan 17, 2012 | 11:31 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
the blinker is definitely a bulb, a fuse would take out all the lights IME
and start with new plugs/wires/cap rotor and go to a new coild if that doesnt do it.
Old Jan 17, 2012 | 11:52 PM
Frozen_Joker
Def a tune up. And don't go too cheap on your tune up, people commonly make this mistake. I never go cheap when it comes to my baby. Cheap as in quality cheap. Dealer wires are some of the best wires around.
Old Jan 19, 2012 | 08:45 PM
jswank's Avatar
jswank
tried new plugs an coil an it still wont start starting to wonder if it aint the cam sensor.. Were is the cam sensor located at? If it is the came sensor will there be a code?
