Need help ASAP
So spring is almost here and my 2002 Durango sxt 4x4 is screwing up!
The cv joints are both going and when I pulled the passenger side off the axle shaft was rounded smooth! Am I able to just pull both cv joints off for now and leave them off? I don't need the 4x4 and won't have the money to fix for a couple weeks and other vehicle is already in shop!
Need answers ASAP need to get it fixed
Oh ****!!!!
Well what about the insert collar on the diff end? What I am talking about is the little collar that the axle shaft plugs into and snaps when you replace the CV Half Shaft?
If it is good maybe everything else is ok and you will need to do a flush on the front differential. If it is bad then you are looking at a junk yard or dealer. It really is just a collar and snaps in before the axle pushes in and snaps in.
Just double checked my 4X4 front wheel bearing rebuild pictures, where I tried to rebuild one and failed miserably.
Moabax is correct, however incorrect at the same time. It is held together with the axle nut. However as for "Bearing Preload" comment, that is incorrect because there is an internal shaft that is "fixed" and the bearings are pressed on, therefore a "Bearing Preload" is not used, only clearance on the main shaft. Besides that, even if there where a bearing preload it would be in Inch lbs, not Foot lbs.
The correct specification for that main axle nut is (180 ft. lbs.)
Trending Topics
I have replaced CV axles before but none looked like this.
