Thermostat Question
Well I found the bolt after a few more hours of searching. Of course it managed to squeeze its way so far down I had to tear apart a bunch of stuff to be able to grab it...Anyway I put everything back together, but know I have a problem. 1st: There is a very small amount of smoke coming out of my intake manifold....2nd: Its smoking really bad where the lower and upper rad hose connect where the metal cap is. I dont see any leaking coolant, just a lot of smoke and condensation around it....Please help. I sometimes think my Durango's only goal is to make my life miserable....Thank you
Trending Topics
you just did the plenum gasket from the first post, i would say oil coming out would mean you did not succeed, however it is also possible that it is just residual rtv burning off from the heat of a hot engine, beyond that idk what would cause smoke to come out of the tb, but i would say that it is not a good thing
Ok, today I noticed my coolant level was pretty darn low in my radiator after running it for a few minutes. When I turned it off, I kept hearing like a gurgling noise coming from the radiator...Also the hose that connects to the thermostat(upper?) IS really really hot but the one going in the radiator(lower?) is cold...like not even a lil warm...Is this normal? HELP! I dont want to take it to a mechanic
