Will 31s fit on a durango
Old Mar 25, 2012 | 09:11 PM
noman's Avatar
noman
Default Will 31s fit on a durango
I have a 99 durango with 235 75 r15s. Its not lifted and right now I'm not planning on putting one on. I do want a more aggressive tread though and a little bit bigger tire. I was looking at 265s or 285s but I'm having a hard time finding the tire I want in that size. So my question is will 31s or 30s on the durango?
Old Mar 25, 2012 | 09:31 PM
mikeismadness's Avatar
mikeismadness
I've seen many stock durango around here runnin 31
Old Mar 25, 2012 | 09:35 PM
DomsDodgeDingo's Avatar
DomsDodgeDingo
31's will definitely fit stock ride height. Have you thought about the torsion/shackle lift? You'd then be able to probably fit 33's on. I recommend doing a search as there is a ton of information on tires and sizes around here.
Old Mar 25, 2012 | 09:37 PM
mikeismadness
+1 the torsion/shackle lift is simple
Old Mar 25, 2012 | 10:17 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
31s will fit stock, thats the size of tire that came on my truck from the factory.
also t/s lift will not fit 33s without rubbing you also need a body lift (or a comically narrow tire)
Old Mar 26, 2012 | 12:18 AM
hydrashocker's Avatar
hydrashocker
Will 31 X 10.5 X 15's fit? The answer is yes. End of topic as I see it.
Old Mar 26, 2012 | 08:33 AM
noman's Avatar
noman
Thanks for the help. I have looked into a torsion shackle lift. That may be a future project. I haven't decided yet.
Old Mar 26, 2012 | 02:43 PM
RollerRed's Avatar
RollerRed
Sorry to hijack!
But I am going 265/65R18 here soon and it is 32.8" tall, and 11.1" wide. I am going aftermarket on the rims that are 18x9's with a 5.71" BS. If I do the T/S lift and cut a little bit anyone think we can do this?
Old Mar 26, 2012 | 04:43 PM
shrpshtr325
THE ULTI-MOD
i wouldnt suggest it, those plastic fenders are there for a reason, to keep water off the electronics in the engine bay, cut them down and you start letting alot more water in while driving, water and electronics do not mix.
can you physically do it? most likely, however i recommend against it.
roller, you should have started your own thread
Old Mar 26, 2012 | 04:49 PM
DomsDodgeDingo
Yeah your gunna get alot of crap in Places it shouldnt be...
