Serious over heating problem!
Old 04-15-2012, 08:58 AM
Dreddlox's Avatar
Dreddlox
Dreddlox is offline
Default Serious over heating problem!
Hey folks! I ran into a problem with my 01 Durango this morning and was hoping you guys could me again! While heading out this morning, I hit the hiway and within 2 mins the temp gauge was nearly pinned! I tried dumping some heat out, but it was only blowing cold air. I pulled over to let the engine cool down for a bit and she gave me a hard to getting started again. This process happened one more time limping it back home. My thought was the water pump, but I wanted to check here first for answers. Thanks in advance for your time and attention!
Old 04-15-2012, 10:48 AM
mikeismadness's Avatar
mikeismadness
mikeismadness is offline
Is there any leak? Did you check the antifreeze?
Old 04-15-2012, 10:50 AM
samnbensdad's Avatar
samnbensdad
samnbensdad is offline
Sounds like you coolant it's either low or not circulating well. If it is full, you are looking at a bad water pump or clogged radiator. Does your fan have any back and forth play on it?
Old 04-15-2012, 05:53 PM
dolittle's Avatar
dolittle
dolittle is offline
Change your thermostat.
Old 04-15-2012, 06:01 PM
DomsDodgeDingo's Avatar
DomsDodgeDingo
DomsDodgeDingo is offline
Your thermostat could be stuck closed.
Old 04-15-2012, 07:46 PM
Dreddlox's Avatar
Dreddlox
Dreddlox is offline
Thanks for the reply all! I ended up having a hole in one of the freeze plugs. All is well again! Thanks for the help! While having the radiator flushed, we found the leak!
Old 04-17-2012, 09:04 PM
DomsDodgeDingo
Glad you got it taken care of. While we are on the subject I have a quick question myself. Is it normal when you unscrew the radiator cap to see no coolant in the hose?
Old 04-17-2012, 09:59 PM
mikeismadness
No, u should always see coolant in that hose
Old 04-17-2012, 10:17 PM
adukart's Avatar
adukart
adukart is offline
+1 mike. How is the reservoir? It should have fluid in it also.
Old 04-17-2012, 10:22 PM
DomsDodgeDingo
Well thats the thing. I drained my radiator b4 I did my Plenum and just filled up the resovoir. Am I supposed to poor coolant in the radiator cap to?
Quick Reply: Serious over heating problem!
