Who has the highest miles on their 1st generation Durango?
Old 12-14-2013, 01:54 PM
PublicHair's Avatar
PublicHair
PublicHair is offline
Originally Posted by cmikolajczyk
I just noticed this post. You said expensive tires? Maybe compared to a car, but 15in rim truck tires are the cheapest on the market! You get brand new mud tires from walmart for $135 a tire for wranglers, and $88 a tire for regular cheap-o 15's. Try that on any other truck or SUV. My 04 Yukon takes 180 a tire.
..well you did forget to notice he said he started driving it in 2008. Assuming he got his L’s at 16yr old, that would put him around 21yr old now. Odds are he’s a young buck still trying to find his way in life with limited funds.
..anywho, tires can be expensive. All depends on what you want from your tire.
The tires I currently have on my Durango are $220 a piece. The ones on my fusion are $180 a piece.
But I go for premium tires and it pays off
  #72
Old 12-14-2013, 01:56 PM
PublicHair's Avatar
PublicHair
Originally Posted by SoonerWildcat
My 2001 dodge Durango RT has now hit 456,730! I really think Dodge should send me a t-shirt or something! Lol!
Originally Posted by that_guy
Pic of the odometer? You 're definitely in the top 5 or so with that mileage. I'm not positive, but I think I heard that someone has over 600,000miles somewhere.
True. Deff in the top tier but that’s only if no rebuild.
End of the day, his Durango is an 01 same as mine and mine is nearly mint condition inside and out. His can be a total bucket with torn leather and rock chips. Yet I’m only at 180k miles..
It’s all about the motor in this case. I’m not sure if the tranny will disqualify though..
  #73
Old 12-15-2013, 02:11 AM
cmikolajczyk's Avatar
cmikolajczyk
cmikolajczyk is offline
Originally Posted by PublicHair
..well you did forget to notice he said he started driving it in 2008. Assuming he got his L’s at 16yr old, that would put him around 21yr old now. Odds are he’s a young buck still trying to find his way in life with limited funds. ..anywho, tires can be expensive. All depends on what you want from your tire. The tires I currently have on my Durango are $220 a piece. The ones on my fusion are $180 a piece. But I go for premium tires and it pays off
What tires are you putting on it that cost 220? That's almost $900 for a set of tires for a durango, that's crazy expensive! But you said premium? So I take it bigger rims as well.
  #74
Old 12-15-2013, 12:14 PM
Speedygtrr's Avatar
Speedygtrr
Speedygtrr is offline
]245 and still running strong but for a little noise in the rear end but only when I turn the
Steering to the right or left for a little bit
  #75
Old 12-15-2013, 12:38 PM
PublicHair's Avatar
PublicHair
Cooper discoverer atr class c in a 265/75r16 size. They don't make em anymore and hard to find. Lowest i found was $193 just now per tire.
4.5 out of 5 rating from 993 reviewers.
http://ssl.delti.com/cgi-bin/rshop.p...=1387128993000
I have about 20k miles on these and still deep tread. Very impressed. However I think I'm going to swap them out for some duratrac from Goodyear. They are all season snow rated which will make my mountian travels easier when chain laws are in place.
  #76
Old 12-15-2013, 09:10 PM
cmikolajczyk
Those are pretty good, but i like a little more aggressive tread. I've got the Rocky Moutain - Falken tires on my Rango. (31x10.5R15LT)
For my 16in rims on my rams, I went with the Hercules Terra Trac A/T. I could pick up a set of 4 for $600. (285/75/R16) They gave me a pretty good 3,300 lb rating per tire. I believe they were the equivalent of a 33in tire? Please correct me if you know for sure. The terra tract a/t II has a 3750 lb rating per tire, but the 3,300 was enough for what I was towing, even with my 2500. Great tires guys, ya'll ought to look into them.
http://www.herculestire.com/results.aspx?w=285&ar=75&d=16
  #77
Old 12-17-2013, 07:12 PM
thepeshmode's Avatar
thepeshmode
thepeshmode is offline
just passed 220K miles last week. With my job and road time will easily hit 250K around next August (2014). Just now the starter is getting tired and the cat is showing signs of plugging. Was expecting these after 10 years of performance.
  #78
Old 12-29-2013, 12:33 PM
kabur98's Avatar
kabur98
kabur98 is offline
I've got about 130K on mine. I replaced the ball joints like just about everyone. Had the tranny rebuilt at about 110K and mostly just maintenance otherwise. Nowhere near you guys with 200K +. I'm not sure I'll get there. It uses a lot of gas but it's big and can tow and has 4WD for my wife in winter.
  #79
Old 12-30-2013, 07:41 AM
99 Durango Problems's Avatar
99 Durango Problems
99 Durango Problems is offline
225,000 on my 99 5.2. Wouldn't trade this tank in for anything. Minor fixes, I.a.c, tie rod, exhaust muffler. Other than it being a thirsty gas hog, no complaints!
  #80
Old 01-07-2014, 05:39 PM
wralyn's Avatar
wralyn
wralyn is offline
128,000 on my '02 4.7L 4x4.
The only repairs have been brakes, front drive axle, and AC compressor. Unfortunately, the AC compressor clutch sounds like it's going out again. I've also got some mystery suspension noises and possible hub assembly replacement in my near future.
Quick Reply: Who has the highest miles on their 1st generation Durango?
