Aftermarket Stereo
Old May 28, 2012 | 10:43 PM
Kensai's Avatar
Kensai
sharp, here an idea we can think of.
http://www.youtube.com/watch?v=Q65f84mjN_8
Old May 28, 2012 | 10:48 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Its going to look about the same as the dash pieces are close to being the same. However, the problem with tablets is no one are the same. Each has connectors in a diff place and sizes are diff
Old May 29, 2012 | 08:20 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
kensai, i like that idea, it seems to work quite nicely
Old May 29, 2012 | 04:37 PM
TurboStixx's Avatar
TurboStixx
Sorry Jmess, have been super busy!
Look up that Model Number, Its a jensen, I used to have the online owners manual, but can't seem to find it!
Old May 30, 2012 | 12:05 AM
jmess's Avatar
jmess
sweet man thanks. thats pretty much exactly what im looking for. a bit nit picky on this though, will it play music from my iphone via bluetooth?
Old May 30, 2012 | 12:30 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
My Samsung BT head piece came with several adapters and one of them was a set of short wires stereo ear bubs you can play music through the BT through the ear buds. Also it came with a mini USB piece you can plus a stereo ear phone cable into and then into head unit or any other source unit that accepts an aux input. That headset was only about $35 i think.
Old May 30, 2012 | 06:21 AM
Prevost's Avatar
Prevost
I like the look of that jenson, but my slt has the steering wheel radio controls, and i want to know if they will still work with an aftermarket radio?
Old May 30, 2012 | 09:33 AM
TurboStixx's Avatar
TurboStixx
That jensen is setup to do navigation, camera, bluetooth, aux cables (hooking up an xbox to it)
It does not work with the steering wheel radio controls, you have to get a super fancy super expensive one for that and then it MAY work, but most aftermarket radios do not work wit the SLT controls (I am running an SLT) I will take a couple more pictures for you jmess I will get them on a lot quicker this time
Old May 30, 2012 | 10:43 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
This is all you need to retain OEM switches
http://www.crutchfield.com/p_127SWIX...X.html?tp=3405
Old May 30, 2012 | 11:35 AM
Prevost's Avatar
Prevost
Thats funny, i found those just before you posted this, thank you guys, ill do alittle more research into it, makeing sure everything is compatible with our rangos. And i know im going to be looking at that jensen UV10, cause that just looks great. And ill post my findings.
