2000 durango wont start
Old 09-23-2012, 04:41 PM
5.9's Avatar
5.9
5.9 is offline
Default 2000 durango wont start
hi. my 2000 durango with the 5.9 wont start. i bought it like this but i cant figure out why it wont start. i got fuel pressure in the rails and my timing light says i got spark. so i thought it was timing because it has over 200k so i put a timing chain in it and that wasent it. this is the first dodge ive ever owned so i dont know to much about them. its got new coil, pick up coil, cap and rotor by the previous owner. i even checked fireing order on the wires. the plugs are really wet so im gonna clean them off and see what that does also there was a lot of gas in the oil when i bought it i assume from people cranking it so much. if u have any ideas please let me know.
Old 09-23-2012, 05:41 PM
Old_School's Avatar
Old_School
Old_School is offline
First, the timing in these trucks is set for you by the PCM... there is no need for a timing light... I would look at the crankshaft position sensor as the culprit.
Old 09-23-2012, 07:11 PM
5.9's Avatar
5.9
5.9 is offline
i thought about that, do you know of a way to check if the old is bad before i buy another one?
Old 09-23-2012, 08:38 PM
Old_School's Avatar
Old_School
Its not being tested on a dodge but, it is the same concept.
Old 09-23-2012, 11:14 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Dodge Forum Moderator
When you replace the timing chain, did you remove the dist?
Old 09-24-2012, 09:21 PM
5.9's Avatar
5.9
5.9 is offline
no i dident touch it
Old 09-24-2012, 10:38 PM
master tech
Thats good. As long as you did touch the dist, the timing should be okay and you don't need to set the sink timing. Have you replace the spark plugs yet? They maybe fouled to the point of not starting.
Old 09-25-2012, 07:51 PM
5.9's Avatar
5.9
5.9 is offline
i tookem all out and cleaned them up because they were really wet with gas. but they look to be in good condition nice and flat
Old 10-11-2012, 08:30 PM
5.9's Avatar
5.9
5.9 is offline
nope crank sensor wasent it. it still wont start. and it really smells like fuel when cranking
Old 10-11-2012, 09:38 PM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
have you checked for spark yet? i dont mean w/ a timing light, pull a wire and put a plug in it, hold it to the block, what do you see? if the spark is not nice and strong id look at coil, wires or distributor cap/rotor
Quick Reply: 2000 durango wont start
