Jack location
Jack location
Hey all,
I wanted to know where the best place is for the OEM jack. I changed my tire today and well the truck slipped forward and fell off the jack stand and jack! My thoughts are that I did not place the jack or jack stand in a secure place.
So I just want to know where would be the best place to put the jack.
I have a 2002 D 4x4 4.7L.
HOISTING RECOMMENDATIONS
WARNING: THE HOISTING AND JACK LIFTING
POINTS PROVIDED ARE FOR A COMPLETE VEHICLE.
WHEN A CHASSIS OR DRIVETRAIN COMPONENT
IS REMOVED FROM A VEHICLE, THE
CENTER OF GRAVITY IS ALTERED MAKING SOME
HOISTING CONDITIONS UNSTABLE. PROPERLY
SUPPORT OR SECURE VEHICLE TO HOISTING
DEVICE WHEN THESE CONDITIONS EXIST.
FLOOR JACK
CAUTION: Do not attempt to lift a vehicle with a
floor jack positioned under:
² An axle tube.
² Aluminum differential.
² A body side sill.
² A steering linkage component.
² A drive shaft.
² The engine or transmission oil pan.
² The fuel tank.
² A front suspension arm.
When properly positioned, a floor jack can be used
to lift a Durango vehicle (Fig. 3). Support the vehicle
in the raised position with jack stands at the front
and rear ends of the frame rails.
HOIST
A vehicle can be lifted with:
² A single-post, frame-contact hoist.
² A twin-post, chassis hoist.
² A ramp-type, drive-on hoist.
NOTE: When a frame-contact type hoist is used,
verify that the lifting pads are positioned properly
(Fig. 3)
FLOOR JACK
² An axle tube.
² A body side sill.
² A drive shaft.
² The fuel tank.
HOIST
(Fig. 3)
MoparMan1991
2001 Dodge Durango
MoparMan1991 - Yea i never had a problem either til today! Man that was pretty scary stuff!
Old_School - Cool! that is what I was looking for! Well thank you!
2001 Dodge Durango
Trending Topics
