265/70/17 tire rub
265/70/17 tire rub
just bough Firestone destination le2 265/70/17 and on wide turns it rubs a little on the bumber screws. what can i do?
http://tinypic.com/r/13z95p2/4
That would be correct if I did not have a typo in the stock size. (My apologies for that) The stock size is 275/60R17 which is 30" tall, that is where the 1.5" comes from.
Yea I agree it puzzles me as well that they don't fit. They technically should fit, but that varies from vehicle to vehicle. Back when these trucks first came out many people with the 17" rims switched to this size over stock since tires in this size were much more affordable. That being said 10-13 years of wear and tear could easily affect the fitment. However, I agree with SJ02 and I would check to make sure the bumper is not sagging or pushing back into the wheel well.
Trending Topics
Check the suspension? Maybe it got weak and your ride height may have dropped slightly but enough to cause the rubbing?
Another thing you need to be aware of. A taller tire to throw your speedometer off so your actual speed will be faster than what the speedometer is saying.
My R/T, using several brands of GPS's, they all show that I am about 2 mph faster than what my speedometer is showing. And I am using OEM sized tires.
You can also look at these tires that I am personally using and the price is not expensive and they are long lasting.
BFGoodrich Long Trail Touring T/A's 275/60/17:
http://www.bfgoodrichtires.com/tire-...go/R%7CT/tires
My 60k miles are almost up for my 1st set of the BFG LT T/A's. Waiting for Costco/Sam's to have another $70 off special to get them replaced with a 2nd set.
