torsion/shackle lift
Old Jun 19, 2011 | 11:36 PM
  #41
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
the t/s lift will allow 32 inch tires iirc
the t/s AND 3inch bl will allow 33 inch tires.
also it doesnt matter how much you spend on the lift if you plan to leave the small tires on the truck, the differential will still be the low point, in order to increase the true ground clearance you need to raise the differential, the only way to do that is with bigger tires.
Old Jun 19, 2011 | 11:48 PM
  #42
srch4me's Avatar
srch4me
exactly... so if you want more clearance you gotta fork out money either way... actually for more clearance you gotta do both... the lift and the tires...
Old Jun 19, 2011 | 11:51 PM
  #43
shrpshtr325
THE ULTI-MOD
exactly correct srch
Old Jun 20, 2011 | 10:36 AM
  #44
mvoss2576's Avatar
mvoss2576
Hmm... well I am going to be replacing tires soon anyway, so I might do the TS - Shackle lift, then get the 32's... would give me an inch or so more...right?
Any recommendations on tires btw.. I started a thread in the Tire section, but nobody responded yet.
Old Jun 20, 2011 | 12:08 PM
  #45
shrpshtr325
THE ULTI-MOD
an exta inch of DIAMETER on the tires, so more like 1/2" at the axle or differential
Old Jun 20, 2011 | 04:05 PM
  #46
srch4me's Avatar
srch4me
personally i like the bfgoodrich mud-terrain and all terrain tires, along with the kumho road venture MT KL71.
Old Jun 21, 2011 | 09:44 AM
  #47
mvoss2576's Avatar
mvoss2576
Hmm.. so, if I did the T/S lift, and a 3" body lift to accomodate 33"s I would only gain about 1" at the differential?
Old Jun 21, 2011 | 10:45 AM
  #48
shrpshtr325
THE ULTI-MOD
correct
Old Jun 21, 2011 | 01:22 PM
  #49
MoparMan1991's Avatar
MoparMan1991
the differential is the weakest point in ground clearance, thats why the military makes their humvees with everything basically up high and inside.
Old Jun 21, 2011 | 02:34 PM
  #50
mvoss2576's Avatar
mvoss2576
Seems like a lot of trouble for just 1" (Looks good though..)
I just thought I would get more clearance. Guess that's what I get for trading in a Chevy pickup 4x4 for an SUV...oh well.
