torsion/shackle lift
Old Sep 12, 2011 | 10:21 PM
  #61
MoparMan1991's Avatar
MoparMan1991
with the torsion lift you should be able to clear 33s with maybe some minor rubbing. I did the T/S lift and Im already looking into another 3 inch body lift. for the T/S lift you need the 2 inch chevy lowering brackets and they are right here. http://www.autozone.com/autozone/acc...er=204654_0_0_
You will need to tighten both torsion nuts 8 full turns and it will get you 2 inches in front. The way the brackets work, on a chevy the shackles are upside down from our trucks, so 2 inches of lowering means the shackles need to be longer. Our shackles are tiny turds and you can see it by just looking at them.
Old Sep 13, 2011 | 12:08 PM
  #62
hydrashocker's Avatar
hydrashocker
33's will only clear safely with a T/S lift and a body lift. 32's will clear with just a T/S lift safely.
Now if you want to run 12.5 wide tires you would need set back rims about 2 inches outward as well, and that would most likely go for even the 10.5/11.5 wide 33 tires.
There is no video out there, but please feel free to make one.
Old Sep 13, 2011 | 12:29 PM
  #63
thenyscrod's Avatar
thenyscrod
Looking at the pics with the rear lowering shackle in place, I noticed on some that the axle is under your leef springs. Mine is not..........and both of the shocks are on the same side of the axle.... ????
Old Sep 13, 2011 | 02:26 PM
  #64
adukart's Avatar
adukart
WTF? Take some pictures and show us, it sounds like the PO lowered it.
Old Sep 13, 2011 | 09:39 PM
  #65
Duranged408's Avatar
Duranged408
I think you may be confused. Regular D's run spring under, slim pickin's finding SOA durango on here.
Old Sep 13, 2011 | 09:55 PM
  #66
adukart's Avatar
adukart
I may be confused, will look tomorrow to un-confuse myself, and yes un-confuse is now a word.
Old Sep 13, 2011 | 11:02 PM
  #67
srch4me's Avatar
srch4me
damn... i love the way your durango looks duranged. the stance is just awesome lol
Old Sep 14, 2011 | 01:10 AM
  #68
MoparMan1991
I'd love to do that on my D but I don't have that kind of money.
Old Sep 14, 2011 | 06:40 AM
  #69
Duranged408
To get a stance like that all you need is $300. Just t/s-3"body- offset rims, the most expensive part are tires. Dont be a cheap bastid
Old Sep 14, 2011 | 11:29 AM
  #70
adukart's Avatar
adukart
So I looked, and as usual was proven wrong. My only question is how can you do a 2in lift with an add a leaf setup? Or is the only option lift shackles? Duranged you should do a video of you wheelin' passin all jeeps.
