Oli consumption
Old Jul 7, 2018 | 03:33 PM
George Genovezos's Avatar
George Genovezos
Default Oli consumption
Hi all,
I have a 2000 5.2 durango. I'm going through a quart every 2 weeks. any ideas what this might be? I don't see any oil leaks on the ground, no smoke at idle or starting off a red light or anything.
Thanks
Old Jul 7, 2018 | 04:03 PM
JeeperDon's Avatar
JeeperDon
Check the antifreeze. Do you park outside and maybe pissed off neighbors are messing with you?
Old Jul 7, 2018 | 04:43 PM
George Genovezos
Coolant is brown, even though I replaced the thermostat and got most of the old brown water out and replaced it with 50/50 preston and water, and I do need to add from time to time. It's not as bad as the oil consumption.
Could be my neighbors. It's not easy being this awesome and driving a dodge. Haters are going to hate.
Old Jul 9, 2018 | 07:02 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
coolant should be green . . .
if its turning brown you need to flush the system, a possibility is a bad headgasket causing coolant and oil to mix, does the coolant have an oily film on it?
Old Jul 9, 2018 | 07:20 AM
This... ^^^
Old Jul 9, 2018 | 09:41 AM
George Genovezos
Agreed. I replaced the thermostat, and flushed all the lines to and from the heater core and back into the block, and radiator, but as soon as I filled it with coolant more brown gunk. I need to do a flush and drain the whole block. WHere is the drain on these things?
No the coolant isn't oily. I don't see any bubble coming out of the coolant when the engine is running so I don't think it's a head gasket.
Old Jul 10, 2018 | 04:26 PM
There are plugs that screw into the bottom of the block, just above the oil pan rail, kinda in the middle of the block.
For the oil consumption, have a look down your throttle body. See oil on the bottom of the intake? That's where it's going. And the truck won't necessarily smoke either.
Old Jul 11, 2018 | 11:28 AM
George Genovezos
Thanks, I'll drain it asap.
I have not looked down the TB yet. I'll take a good look and let you know. What's your thought process?
Old Jul 12, 2018 | 08:09 AM
Dodgevity's Avatar
Dodgevity
Have you gotten under the truck and inspected the underside of the engine? That much oil has to show somewhere.
Old Jul 12, 2018 | 11:19 AM
The intake manifold on your truck is two pieces. There is a gasket between the two pieces, that is a known failure point. We have a thread dedicated to that particular problem in the 2nd gen ram section.
