Durango 1998 5.9L-Magnum rebuild
Old Jan 16, 2019 | 09:20 AM
  #71
You are going to have a brand new truck when you are done.
Old Jan 16, 2019 | 03:50 PM
  #72
Juergen's Avatar
Juergen
thx, I hope so
Old Jan 18, 2019 | 09:59 AM
  #73
Juergen's Avatar
Juergen
new Picture
Wedding
Bodylift 3"
Old Jan 18, 2019 | 10:27 AM
  #74
JeeperDon's Avatar
JeeperDon
Sorry, but the body lift looks absolutely terrible!
Old Jan 19, 2019 | 03:04 AM
  #75
Juergen's Avatar
Juergen
That's how it should be,
i like it,
even bigger wheels come
Old Jan 19, 2019 | 08:41 AM
  #76
JeeperDon's Avatar
JeeperDon
The problem with larger tires on a vehicle like that is the metal fender wheel well is not any larger. Since huge tires will never fit in the wheel wells (for many trucks, not just your Durango), people jack it up way tall. It will always look like a dorked over truck for the sake of larger tires, nothing fits right. I mentioned it because I'm a Jeep guy. In the Jeep world where larger tires are common, we would make the fender wells larger to accommodate the larger tires without lifting it ridiculously high. If you insist on the larger tires, a suspension lift, maybe with solid axle in front, is much better than 3" body lift. You gain zero off-road clearance with a body lift, since the frame is no higher.
I only mentioned all this on the chance you would reconsider. You apparently do not see what I see, or don't care about it, so enjoy your Durango.
Old Jan 29, 2019 | 06:36 AM
  #77
Juergen's Avatar
Juergen
Today the engine started the first time.
First started until oil pressure was, then let run about 10 minutes at increased speed, so that all hydraulic plunger vent well. Sounds really good, I'm very satisfied.
Unfortunately, the sound from the phone is played very poorly
Old Jan 30, 2019 | 09:27 AM
  #78
Juergen's Avatar
Juergen
next stepp is grind and then Raptor Liner
I do not like everyone , I like it
Old Feb 4, 2019 | 04:13 PM
  #79
Juergen's Avatar
Juergen
10.894 views, but only 39 reply (without me), is it boring?
Old Feb 4, 2019 | 05:14 PM
  #80
Not at all. The number of views tells me that lots of folks are interested. Don't sweat the lack of comments. The fact that numerous folks are following your build tells me it's interesting.
