Need help again everyone
2001 dodge durango was not shifting into gear it was half way in between gears. Found a broken shift cable, replaced it, got it as close into adjustment, put it in gear in moves front and back but when u step on the gas the rpms go up and it takes a second to move. Im at a loss, spent taxes on this and been broke more that running already put 800 dollars in parts on it. But after you get it to take off, you can run about 5 mins then goes into neutral i think, shut the key off wait a couple minutes and itll go again. I should also say it has no codes. Not trying to be a sap but just found out i have cancer also, so really need transportation. Any advice will be appreciated. Thank you
Trending Topics
Different transmissions have different level check procedure.
Steve
