Tail light/ park lamps not working
Old Sep 16, 2020 | 10:51 PM
Orion Wright's Avatar
Orion Wright
Default Tail light/ park lamps not working
Light switch is good still, fuse 14 keeps popping. Checked wiring to license plate it’s still good no short. I don’t know how to get to the tail light wiring nor do I know how to check dash light wiring either. I have the book and can’t seem to find how to access all this wiring. Guess I will be pulling dash here soon if it’s not the tail lights.
Old Sep 17, 2020 | 09:02 AM
Got a trailer harness on there? Find where the trailer harness hits the main rear harness. Make sure everything is good there.
Old Sep 17, 2020 | 10:24 AM
Orion Wright
Sorry I forgot to mention that. I actually don’t have one. Read on the forums to check that but my doesn’t even have tow package either.
Old Sep 17, 2020 | 10:48 AM
Leaves that one out then.
Disconnect the rear harness, see if the fuse still blows. That will at least tell you if its the front, or rear, that is causing the issues.
Old Sep 17, 2020 | 11:13 AM
Orion Wright
Will give that a tire when I get home. Let’s say it is rear harness how would I get to the wiring?
Old Sep 19, 2020 | 06:57 PM
Orion Wright
So it’s my rear right one that keeps blowing the fuse I just don’t know how to get to wiring
Old Sep 19, 2020 | 07:27 PM
Orion Wright
Harness is unplugged and the fuse didn’t pop. So is it the tail light harness on the light or the wiring?
Old Sep 19, 2020 | 08:33 PM
Orion Wright
So I got it all figured out. I pulled out the test light and saw I was getting 12v to my grounding unit. I own aftermarket tail lights. Half way plugged in I saw that the 12v was gone. Flipped the plug in to the light plug and no more blowing fuses. Here is a pic of my tail lights. Love them.
Old Sep 19, 2020 | 09:32 PM
The plugs aren't keyed to only go together in the correct way???? That seems like a real oversight.....
But, it's fixed, and that is all that matters.
Old Sep 19, 2020 | 10:48 PM
Orion Wright
right, think good for test lights. I just don’t know why nav4pro had it plugged in backwards from the get go. Just letting anyone know who wants aftermarket tail lights check your harnesses!
