Fixed heater core. New problems :(
Hi all,
Heater core was leaking so I replaced it.
Now I have heat. Unfortunately air only comes from the defrost vent and my cruise control stopped working. I'm guessing it's a vacuum hose somewhere.
I'm hoping it's an easy fix and I don't need to disassemble the whole dash because I might have to "accidentally" drive it off a cliff.
Yep, that's a vacuum leak. Unfortunately, the last place you were playing was under the dash.... so that is likely where it's at.
There is a single line that comes thru the firewall, over by the ac box, under the hood, that supplies vacuum to the control head. Could check there first..... the plastic lines get brittle with age under the hood, and break pretty easy......
Also where do i get a vacuum line that thin or can I use something different?
If you have a broken line under the hood, fix that first, and see if the problem is gone.
For the plastic line, I just use some rubber vacuum line of an appropriately small diameter, so it fits on there nice and tight. Just splice 'em back together. Any parts store should sell the stuff in bulk, just pick up a foot or three, and use as necessary.
Ok. What I have is a T off the brake booster that goes to a very thin line and goes to nothing. It's right next to the heater core in/outlet. I don't see it going anywhere and there isn't another line anywhere. Might be inside the cab but I don't see how it connects from the engine bay to the control head. do you have a pic or something that shows how it connects from the engine vacuum to the control head?
Trending Topics
