Oil in Spark Plug hole 4.7
Old Mar 20, 2023 | 07:31 PM
Jsmitty0823's Avatar
Jsmitty0823
Default Oil in Spark Plug hole 4.7
I have an 02 Dodge Durango with the 4.7 engine with high miles. After sitting for a while a blueish tint smoke comes out the exhaust. The engine is for sure misfiring and when i changed spark plugs and coils i noticed spark plug in cylinder 3 was covered in oil and coming out the spark plug hole. How do i fix this issue? I have not seen any info or How to videos out there, any help would be great. i was told i might have a bad pistion or oil ring?
Old Mar 20, 2023 | 09:09 PM
Probably just a seal between the spark plug hole, and valve cover. If it's leaking, oil will accumulate in there, and when you pull the plug, it all goes into the cylinder.
Old Mar 20, 2023 | 10:29 PM
Jsmitty0823
Ok cool. I will check the valve cover gaskets
Old Mar 21, 2023 | 08:12 AM
Dodgevity's Avatar
Dodgevity
The spark plug holes are away and separate from the valve cover. Maybe the plug wasn't tight enough or got removed a few times and the crush seal was no longer effective. The blue smoke is probably from worn valve stem seals. That would contribute to extra oil being in the combustion chamber and getting past a loose plug as well. Replaced mine a few years back and no more oil loss or smoke. https://dodgeforum.com/forum/2nd-gen...tem-seals.html
Now looking at this pic, technically, if a valve cover seal is leaking at a certain spot, the oil could drain into the spark plug hole, so you'd be right in that sense.
Old Mar 21, 2023 | 10:43 AM
Jsmitty0823
Thanks for that updated advice. And when the coil/plug is tightened down I can wiggle the coil..it doesn't seem to be as snug as the others..
Old Mar 21, 2023 | 01:24 PM
Dodgevity's Avatar
Dodgevity
Which cylinder is it misfiring on? The resulting code should tell you. You can try swapping the coil pack of the misfiring cylinder to another cylinder. If the misfire moves with it, you need to replace that coil pack.
Edit: Just reread and you said you did change coil packs. Still try that.
Old Mar 23, 2023 | 10:16 AM
Jsmitty0823
There's a significant amount of oil on the bottom of #3 cylinder spark plug..I don't think it's leaking from valve covers..
Old Mar 23, 2023 | 10:38 AM
Do you have high oil consumption between changes?
Old Mar 23, 2023 | 11:06 AM
Jsmitty0823
No this issue just started happening
Old Mar 23, 2023 | 11:52 AM
Put some dye in your oil. Drive it for a couple days. Inspect with a UV flashlight. Any leaks will be instantly obvious.
