Throttle Position Sensor Replacement
Old Jul 12, 2010 | 10:35 PM
  #61
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
Originally Posted by Mcstealth
Please, On my '02 4.7L, The TPS is on the T body, drivers side. There are three sensors on the TBody I think I read elsewhere? #25 Torx. As simple as un-click, re-click?
Thanks
David
yup, sounds about right, the tps is on the t-body (not sure which side its on, but its connected to the shaft that the butterfly valve rides on) and replacement is unplug, unbolt, bolt in the new one and plug it in.
just remember to disconnect the battery before you start, and hold the key to start for about 30-60 seconds before reconnecting the battery.
Old Jul 13, 2010 | 12:15 AM
  #62
hydrashocker's Avatar
hydrashocker
Try and help people out and see what happens to a perfectly good thread.....LOL
I'm ignoring you from my view so I just put you on ice. Don't come to me for help bro!
Old Sep 7, 2011 | 06:52 AM
  #63
hammerman33's Avatar
hammerman33
Smile looking for help
did this happen when it was not in cruise mode?
thanks - hammer
Old Sep 7, 2011 | 06:58 AM
  #64
hammerman33
i am still having problems with my 2000 durango r/t after i had a new fuel pump put in. it is clogging up to where every other day i need to run it up and down the highway real fast to clean it out ????? it is like it is to rich and when i change the pump the pressure regulator was also done since it all comes in the same unit. i also put a tune up on it. it will pop like it is backfiring, could that be the timing off or do these newer trucks do that. can you put a timing light on it or do they even use one any more. thanks
hammer
Old Sep 7, 2011 | 12:27 PM
  #65
Old_School's Avatar
Old_School
hammer
After you replace all them parts did you reset the PCM?
Old Sep 7, 2011 | 02:37 PM
  #66
hydrashocker
Most likely a pre-cat O2 sensor. Is it backfiring from the Throttle Body or the Exhaust?
Old Sep 8, 2011 | 01:18 PM
  #67
hammerman33
i am not sure how to reset the PCM and as far as backfireing i am not sure it is when i am going down the road and trying to get it to go. it get so frustrating.
Old Sep 8, 2011 | 01:39 PM
  #68
adukart's Avatar
adukart
To reset the pcm disconnect the battery and turn the key to run for 30sec. Then reconnect the battery, start it and let it idle for 15sec. Re start and drive, it will take approximately 15 cold starts and 40 miles (some one will correct me if I'm wrong on the number) to fully reprogram itself.
Old Sep 8, 2011 | 07:21 PM
  #69
shrpshtr325
THE ULTI-MOD
40-500 miles to fully relearn, but otherwise you nailed it.
Old Sep 8, 2011 | 09:35 PM
  #70
hydrashocker
I stand by saying the pre-cat O2 sensor is out.
