is it 5.9 magnum??
Old 01-17-2007 | 05:12 PM
JaymZz's Avatar
JaymZz
Default is it 5.9 magnum??
good eveing guys, the other day i checked a 1999 durango
its clean, and its taken car of
so i really wanna know if the 1999 model is worth to obtain
and the on ein the picture, is it 5.9?couze i really didnt asked about the engine
[IMG]local://upfiles/40505/ED6628CBC513416797ECB6FDA4D6F517.jpg[/IMG]
[IMG]local://upfiles/40505/82E21F391E654ED695397E408A0B9A4C.jpg[/IMG]
[IMG]local://upfiles/40505/DB80B0871CB64EF58650FBA5EE00F645.jpg[/IMG]
Old 01-17-2007 | 05:42 PM
ccusum's Avatar
ccusum
Default RE: is it 5.9 magnum??
It hard for me to tell, but if you look on the underide of the hood, there should be a white sticker. That will tell you the size of the engine.
Old 01-17-2007 | 06:37 PM
Natedogg625's Avatar
Natedogg625
what is the 8th digit of your vin number? This is what tells what engine you have.
if it says 5 or Z than its a 5.9 (5 is heavy duty, and Z is light duty...I think Z is for R/Ts...not sure)
if it says Y than its a 5.2
Old 01-17-2007 | 07:36 PM
steve05ram360's Avatar
steve05ram360
another way to tell is to look at the block...
above the starter...
[IMG]local://upfiles/1508/7557F9D45C11498FBEFEBC345EB622F2.jpg[/IMG]
Old 01-18-2007 | 03:00 AM
Mean Green's Avatar
Mean Green
That is either a 5.2 or 5.9 from the pics. As stated above you can check it out to be sure of the size. I am pretty sure the sticker in the glovebox would tell you what engine you have as well as gear ratio and transmission type. Both engines are solid so it's all preference from there.
Old 01-18-2007 | 03:13 AM
HeavyD's Avatar
HeavyD
you could alway ask the owner, as stated only the 5.2(318)or 5.9(360) was available in 99
Old 01-18-2007 | 01:17 PM
Mean Green's Avatar
Mean Green
Didn't they offer the 4.7 in the early days (98-99) too?
Old 01-18-2007 | 01:25 PM
jonnymagnum's Avatar
jonnymagnum
ORIGINAL: Mean Green
I dont think they came out with the 4.7 till 2000 or 2001.
the 4.7 replaced the 318
Old 01-18-2007 | 01:52 PM
2000RT's Avatar
2000RT
I may be wrong, But doesn't the 5.9 have the radiator cap placed on the upper
radiator hose. My 2000 5.9 does. The pic shows the radiator cap on the radiator, so
(If my assumption is correct) it is the 5.2
Old 01-18-2007 | 01:54 PM
jnellydodge's Avatar
jnellydodge
ORIGINAL: 2000RT
+1,
i too think that the 4.7 was introduced in 2000
Quick Reply: is it 5.9 magnum??
