1st Gen Intrepid 1993 through 1997 Intrepids
Dodge Intrepid 1996 Chassis problem!
Old Apr 26, 2010 | 04:24 AM
Dodge1996's Avatar
Dodge1996
Default Dodge Intrepid 1996 Chassis problem!
okay long story short my chassis broke on the right side of the car. where the axle is at and the bottom arm where it holds the whole side of the tire,brake rotor and so on..(sorry for my bad english)..where could i find another chassis?..i been told im gonna have to replace it and its not possible to get it welded..
any help on this guys?..any input that i should know?..
if pictures needed let me know..
Old Apr 26, 2010 | 12:29 PM
Dodge1996's Avatar
Dodge1996
anyone?...
Old Apr 27, 2010 | 08:03 PM
kurts2's Avatar
kurts2
I'd add some photos... Help us to help you.
Old Apr 28, 2010 | 02:00 PM
Dodge1996's Avatar
Dodge1996
ill get pics ASAP when i get home from work!
Old Apr 28, 2010 | 06:02 PM
Dodge4lyfe's Avatar
Dodge4lyfe
It sounds like you are talking about the engine cradle(or K frame) as these are unibody cars and don't technically have a frame. If this is the case, you can get one from a junkyard off of any LH body Chrysler (LHS, Concorde, New Yorker, Intrepid, Eagle Vision) that has the same engine.
Old Apr 30, 2010 | 02:08 AM
Dodge1996's Avatar
Dodge1996
engine cradle??..thats this right??https://w05.dealerconnect.chrysler.c...S/80151ed6.gif
Old Apr 30, 2010 | 07:21 AM
Dodge4lyfe's Avatar
Dodge4lyfe
yeah that would be it...
Old May 2, 2010 | 12:06 AM
Dodge1996's Avatar
Dodge1996
one more question??..what do i need to remove or get loose to remove the engine cradle?..
Old May 2, 2010 | 09:23 AM
kurts2's Avatar
kurts2
Go to the top of the second gen forum and see the post the holy Grail. The procedure should be about the same and will give you an idea on what to expect
Old May 12, 2010 | 07:38 AM
ralphael101's Avatar
ralphael101
Just wanted to make sure that you know that you can replace the lower control arm. Hope this helps. I find it hard to believe that the cradle broke.
