Question about atx to mtx swap
I am doing a mtx swap to my neon i just bought i also have my old one that gut totaled it is an mtx i know the basic stuff i need like the tranny,clutch and
brake asembley,pcm,shifting
linkages and shifter assembley my question will the atx have the plug in for the netural swafty switch that yellow wire and yellow with red stripe wire?b/c i don't see it on the atx is it tucked up some where?Orwill i have to bypass the netural safety switch if so how do i do that? They are both 95 neon sport coupes the atx i just bought is a NYG neon and will post pics of it real soon.
I just did this last weekend so it is somewhat fresh in my memory.
The atx has a plug with 3 wires ,the middle wire is the one you need (black /yellow stripe).
The clutch/brake assembly that I aquired has a switch with 2 yellow wires attached to the clutch peddle.
I ran the (black/yellow stripe) wire that went to the old atxto 1 wire on the clutch peddle the other wire I grounded to the body. So when you press the clutch the car will start........
No a/c
No heater
no dash
no glass (window net)
No lights
No carpet
1 seat
nothing else inside or out(beer can with motor)
roll cage, race seat, race tires!![Big Grin](https://dodgeforum.com/forum/images/smilies/biggrin.gif)
No a/c
No heater
no dash
No lights
No carpet
1 seat
Sorry to bring this back agian guys. But i have one more question about this. Where do you splice the black wire in at from the tranny. Do splice in at somewhere from inside the car?I guess what i am saying is do i have to run that wire clear from the trany to the inside of the car or do i splice it from inside the car some where?
Trending Topics
i added wire from down by the trans, you can actually pull them back out of the harness and they go right up by where you need them. its easier to just pull them out and add wire if needed.
the other 2 conntect to turn on the reverse lights![Wink](https://dodgeforum.com/forum/images/smilies/wink.gif)
find a plug from a MTX car and hook them to the swtich on thetrans if you need them to work.
Yeah i need the reverse lights to work the car is going to be street legal. Do you have any pics of how to set this up. Wireing is deff not my strong point. Now i do have the entire wireing from a mtx my car was totaled so i gutted to whole thing and found a nyg thats a atx and im going to turn it into a mtx would it be easier for me to splice it or just change to whole wireing?
