S0HC 0R D0HC ??? CAN Y0U TELL
Old 09-03-2007, 06:56 AM
[::M0NEY.MAKER]'s Avatar
[::M0NEY.MAKER]
[::M0NEY.MAKER] is offline
Default S0HC 0R D0HC ??? CAN Y0U TELL
AiGHT i WANTD T0 KN0W H0W D0 i KN0W iF i HAVE A S0HC ENGiNE 0R A D0HC???? i D0NT HAVE ALL MY PREVi0US REC0RDz F0R THE CAR....i B0UGHT A NE0N FR0M MY UNC'
Old 09-03-2007, 07:17 AM
Slashwannabe's Avatar
Slashwannabe
Slashwannabe is offline
Default RE: S0HC 0R D0HC ??? CAN Y0U TELL
If it has ***** its a SOHC
The resonator under the hood should say what it is.....
If not then take a look at these pic's : )
Here's a SOHC Engine
And here's a DOHC Engine:
Old 09-03-2007, 08:08 AM
spudsterier's Avatar
spudsterier
spudsterier is offline
that bottom one is a very sexy dohc engine
from the pics, notice the diffeence in the size of the heads.....on the left side of the motor, a sohc wil have 1 hump on the plastic cover......top pic shows the hump...
thedohc has 2 humps, my motor in the bottom pic didnt have the timing cover on it when the pic was taken, but here is another with it......
also, if you notice, the spark plug wires on a sohc kinda sit angeled ON the calve cover.....with a dohc the plug wires sit more IN the top of the valve cover
[IMG]local://upfiles/29901/85E444CDB6474A1E9EAD1A4872F8964D.jpg[/IMG]
Old 09-03-2007, 11:17 AM
[::M0NEY.MAKER]
THANx
Old 09-03-2007, 11:20 AM
[::M0NEY.MAKER]
i GUESS 0BVi0USLY THE D0HC iS BETTER HUH???....L00Kz HELL 0F AL0T BETTER
Old 09-03-2007, 11:33 AM
bone33's Avatar
bone33
bone33 is offline
that DOHC is far from stock.
Old 09-03-2007, 11:50 AM
estneon's Avatar
estneon
estneon is offline
spud that sure was a good build[8D]
Old 09-03-2007, 12:12 PM
Aerorat's Avatar
Aerorat
Aerorat is offline
One way to tell if it is a sohc or a dohc without opening the hood (that is if the hood has been changed) Is if the hood has a bulge on the passenger side it is a dohc if not it is a sohc.
Old 09-03-2007, 01:32 PM
Slashwannabe
ORIGINAL: [::M0NEY.MAKER]
Theres 9 Second SOHC engines running at the Strip which is among the fastest Neon times ever within a half second, it all depends how much you want to stick into your engine. Both the DOHC Engine and SOHC Engine have 4 Valves per Cylinder, I guess theonly reason people can outright tell me the DOHC has an advantage is you can adjust your Exhuast side Valves, The SOHC engine isnt a slouch at all, in stock form a SOHC Automatic car will own a DOHC Automatic.
Personally I don't think your getting screwed no matter what Engine you have, a good driver and a properly modded SOHC can make any DOHC equiped car work for its reputation.
Pretty much just get a 5 speed and both engines come to life with good results
Old 09-03-2007, 02:05 PM
spudsterier
ORIGINAL: Aerorat
thats not entirely accurate if the car is a 95 since alot of 95 sohc sport came with the sport bulge hood
and yeah, that dohc is VERY far from stock
Quick Reply: S0HC 0R D0HC ??? CAN Y0U TELL
