Just bought a 95 neon
Old Sep 8, 2007 | 11:59 AM
blueberry's Avatar
blueberry
Default Just bought a 95 neon
Well i just bought a 95 neon..4 door. I have a few questions and problems.
The guages come on and off..I want to fix this so i can always have guages..What should i do?
I pulled the E-brake and now its stuck on..How do i adjust this?
It has a new headgasket,radiator,fuel fill hose thing,water pump and tires. I am currently undergoing re-painting the whole car. I will post pictures later.
Thanks!
Old Sep 8, 2007 | 02:53 PM
blueberry's Avatar
blueberry
Default RE: Just bought a 95 neon
Well..Found my guage problem.. https://dodgeforum.com/m_179505/tm.htm
Now how do you fix the ebrake
Old Sep 8, 2007 | 04:24 PM
12 volt's Avatar
12 volt
do you have rear disk brakes. you could remove the center console and make sure the the sping in the handle is not jammed
Old Sep 8, 2007 | 04:35 PM
bone33's Avatar
bone33
rear ebrake adjustment is one of the most basic things any car owner should learn. in order the get the ebrake unstuck you are going to have to loosen the adjustments, so you can get the drums off and replace the cable if need be.
put rear of car on jackstands.
do not take off the wheels
locate the drum.
remove the rubber plug on the back
put in a flatblade screwdriver or brake tool into the hole and loosen the adjustment spindle till the wheel spins with just a little drag.
Old Sep 8, 2007 | 04:37 PM
bone33's Avatar
bone33
by the way if your ebrake is getting stuck its prolly due to lack of maintenence. so a good going over your brakes is a good idea.
Old Sep 29, 2007 | 02:39 PM
blueberry's Avatar
blueberry
Alright..still working on painting it. I started it up the other day and it didnt start. Just clicked. Figured it was just the battery..So i swapped a battery from my DD and it turned over. I relized that it was almost out of gas so i put some gas in it. Well then i went to start it up again and just click.
What is my problem? The headlights are dimming when i turn the key
thanks
Old Sep 29, 2007 | 02:48 PM
Jr. Mechanic's Avatar
Jr. Mechanic
Did you drive it with the new battery? How many times did you turn it over? I know mine killed the battery, so I put a new one in it, then the next day it was dead again. I took it to advance and they said the alternator was charging, so I checked all the lights. Sure enough, with the trunk closed, I opened the back seat and the trunk light was staying on. I just un-plugged it, but there is a little switch that is just a piece of metal that is in the latch that was bent and it stayed in the on position.
Old Sep 29, 2007 | 02:50 PM
blueberry's Avatar
blueberry
Nope..never drove it with the new battery
Rolled over like 3 times..not even 10seconds..im 100% sure its not the battery..After i was done i put it in the car it came out of and it started right up.
Old Sep 29, 2007 | 04:09 PM
12 volt's Avatar
12 volt
you migth have to clean the battery treminals.
Old Sep 29, 2007 | 10:08 PM
kris95neonspt's Avatar
kris95neonspt
Check the terminal ends for some reason there very sentive try wiggleing them around on the battery.I know mine have done that several times to me.
