frankinmotor need help
Old Oct 9, 2007 | 07:23 PM
romeo21's Avatar
romeo21
Default frankinmotor need help
ok i have a 96 neon and a 95 neon now a hope i dont lose anyone on this but would it be possible to put the head from the 96 on to the block of the 95 the reason i ask is cuz the the head on the 95 is busted it i think the cam shaft was not toucrked right and over spun and i have blown the block on the 96 i snaped rods 1 and 2 and they punched thorow the front and back so i was thinking if i could mix and matck the to motors into one please help i miss my car
Old Oct 9, 2007 | 07:47 PM
78PowerWagon's Avatar
78PowerWagon
Default RE: frankinmotor need help
I've got a 95 Neon and I swapped the sohc from a 97 to a 95 alls that I had to do is swap the sensors since the 95 is obd1 vs obd2 You shouldnt have a problem swapping Sohc heads.
Old Oct 9, 2007 | 07:58 PM
romeo21's Avatar
romeo21
so then it is possible do you remember witch sencers had to be swaped
Old Oct 9, 2007 | 08:29 PM
78PowerWagon
I think just the cam sensor. Which Intake and exhaust manifold r u gonna use? It shouldn't really matter just check the pin outs f th sensors on the had ur swapping to the one thats on the motor now.
Old Oct 9, 2007 | 08:30 PM
78PowerWagon
Swap the Sensor from the 95 head to the 96 head that ur gonna use.
Old Oct 9, 2007 | 08:39 PM
romeo21's Avatar
romeo21
dude you rock thanks alot i thought it would work but i wasnt sure if you have friends on hear can you have them read this so i can have more confermation thanks alot
Old Oct 10, 2007 | 09:51 AM
das2123's Avatar
das2123
I have a 95 head on my 96, so you can go the other way as well. All I had to change was the CTS.
Old Oct 10, 2007 | 01:59 PM
romeo21's Avatar
romeo21
whats the cts i have never heard of that is it easy
Old Oct 10, 2007 | 02:03 PM
das2123's Avatar
das2123
Coolant temp sensor. It's on the driver's side of the head and it's easier to change it while the head is off the car.
Old Oct 10, 2007 | 02:32 PM
romeo21's Avatar
romeo21
coool now how do i check to make sure the block is still good do i just a comprestion tester and if i swap the heads im going to need a new head gaskit right
