short shifter finished
Old Oct 12, 2007 | 06:55 PM
justinsanders's Avatar
justinsanders
Default short shifter finished
it was easy and a spur of the moment thing. i was just wantin a new shift **** and figured while i was at it i would make it a short shifter. all youneedis a $5.99 **** and a hacksaw and a hammer to remove the old pin installed to hold the old **** in.all i did was remove the old **** and cut about 5 inches off and install a new **** it was that simmple and now i have a short shifter...
[IMG]local://upfiles/63489/D80C929219FE48C1B7E5717962B30439.jpg[/IMG]
Old Oct 12, 2007 | 08:06 PM
12 volt's Avatar
12 volt
Default RE: short shifter finished
why did you what it shorter?
Old Oct 12, 2007 | 08:59 PM
justinsanders
shorter throw=less time between shifts
Old Oct 12, 2007 | 09:23 PM
spudsterier's Avatar
spudsterier
you have a short shifter, but its still not a short throw shifter
a real short throw shifter like the hurst has the bottom part of the hadle bent a bit and lengthened....not just the top cut off.....
Old Oct 12, 2007 | 09:25 PM
justinsanders
yea i kno its not a true short throw shifter but your arm does move less so it does help, although it is harder to move cuz theres less leverage. so what is the difference between a real one. i dont get it. how does it work.
Old Oct 12, 2007 | 09:28 PM
spudsterier
on a real short throw shifter, the bottom of the handle is bent just a bit and is a little longer....the closer the bottom of the handle is to the cables, the less length that it has to move
Old Oct 12, 2007 | 09:29 PM
justinsanders
so its the same height as the stock one but just moves less?
Old Oct 12, 2007 | 09:32 PM
spudsterier
the top is just a little shorter but not much....i think the top of the hurst is only about 1/2 inch to an inch shorter then the stock shifter but the most noticable difference is in the bottom
Old Oct 12, 2007 | 09:35 PM
justinsanders
oh ok now i get it. i kinda basically did the same though. all that matters is how much your arm moves right? although i agree that a real short shifter is better cuz u have more leverage and still have a short throw. because mine is kinda hard to move in and out of gear. am i right?
Old Oct 12, 2007 | 09:53 PM
spudsterier
the whole principle of a short throw shifter is to have less movement for your arm...but in less arm movement you also have less shifter movement
