torque converter solenoid problem?
Old Oct 16, 2007 | 10:06 PM
954drneon's Avatar
954drneon
Default torque converter solenoid problem?
i am throwing a check engine light on my 95 neon......says the following:
code P0743
and it exlplains like solenoid short circuit or malfunction......
possible causes ....low or poor tranny fluid.....open or short.....failed torque converter clutch.....failed solenoid...........electrical problem...
what is most likely my problem? i am fixing this car and i am not very experienced with neons..........but if this problem has been seen before what is most likely my problem?
oh and the car drives weird...........like no torque at all and it just revs sometimes and then it will jump into gear............
thanks in advance
Old Oct 16, 2007 | 10:50 PM
Girlski's Avatar
Girlski
Default RE: torque converter solenoid problem?
i work at autozone, an most of the time its either lose tranny fluid or a short
Old Oct 16, 2007 | 10:57 PM
954drneon's Avatar
954drneon
ok. thanks....where will the short normally be?
Old Oct 16, 2007 | 10:58 PM
Girlski's Avatar
Girlski
usually, by where the most heat is created and that makes the wiring fragiles and creates more resistance and the voltage and stuff is loss because of it
Old Oct 16, 2007 | 11:35 PM
954drneon's Avatar
954drneon
oh great thanks very much i will follow the wiring back to see if there is a short and then check the fluid.............but if its not one of those things then i guess i am in trouble LOL
Old Oct 17, 2007 | 12:02 AM
master tech's Avatar
master tech
Site Moderator & Tech
Replace the torque converter lock up soleniod switch. Mopar part number is 4799954aa. You will need to remove the valve body.
Old Oct 17, 2007 | 01:45 AM
954drneon's Avatar
954drneon
can i unbolt it like a speed sensor? and replace it?
Old Oct 18, 2007 | 12:04 AM
master tech
After the valve body has been removed there are 3 or 4 screws holding the solenoid to the valve body, and be careful the solenoid is spring loaded. Has two springs. and reseal the pan with black rtv silicone.
