A minor delay........
Old 03-29-2008, 02:06 PM
jfink's Avatar
jfink
jfink is offline
Default A minor delay........
well replaced one rear strut and started on the bushings when the bolt for the lateral link going throu the crossmember broke off. so F$#@ing son of a B$#@# G$# D@#$%^. while i search for bolt specs can anybody help me out with either removing the rest of the bolt cause its stuck or specs on the bolt, and any other specs on the rest of the bolts. it would be greatly appreciated. supposed to be a one day job.
this is what i'm dealing with!
Old 03-29-2008, 02:23 PM
fsu182's Avatar
fsu182
fsu182 is offline
Default RE: F@!* son of a B#$%@..........
oh my... that really sucks. ive learned that almost everything i do to my car requires a can of rust eater.... u could drill it out?
Old 03-29-2008, 02:28 PM
jfink's Avatar
jfink
jfink is offline
afraid of that. probably what i'll end up doing. called the parts department at the local dealership and they said that the specs for the bolt are 12x1.75 with a 6g242 in it. he couldn't tell me why it had the 6g242 so it might be a specialty bolt which sucks but i'll go to the local parts store and find the bolt if it looks the same i'll get it and see what it does. but in the mean time @#$#%$# @%% #$$# %#$.yea.
Old 03-29-2008, 03:20 PM
12 volt's Avatar
12 volt
12 volt is offline
naa man, that bolt can be pushed out if you took the head off. its just a long bolt with a nut on one side.
i can send you a used one if you cant find a replacement
Old 03-29-2008, 04:18 PM
jfink's Avatar
jfink
jfink is offline
been all over the place, home depot, lowes, autozone, advanceauto parts, even a tractor supply store. NOBODY has a bolt long enough. damnit(excuse the language). thanx 12volt but there is a dealership close by that has one in stock just won't be open till monday. but does anybody know if you can use a peice of threaded rod with two nuts on each end?? not forsure with the toe adjustment thing.
Old 03-29-2008, 04:26 PM
bone33's Avatar
bone33
bone33 is offline
this is why you always use heat when removing a rusted bolt/nut.
Old 03-29-2008, 05:45 PM
jfink's Avatar
jfink
jfink is offline
tried that on the bolt that goes through the knuckle......didn't work had to burn the bushing off on the car.try that on the crossmember one. anybody know if a threaded rod would work with a nut on each end, instead of a bolt?
Old 03-29-2008, 05:50 PM
12 volt's Avatar
12 volt
12 volt is offline
im sure it will work. if it is stong enough would be my question, you dont want your camber to go positve on the highway.
Old 03-29-2008, 05:51 PM
bone33's Avatar
bone33
bone33 is offline
ORIGINAL: jfink
you should be using at least grade 5 hardware and grade 8 if you race or drive like u stole it. threaded rod is grade 2, so i would not use it. too soft.
Old 03-29-2008, 05:56 PM
bone33's Avatar
bone33
bone33 is offline
http://www.fastenal.com/web/location...061+&state=
they will have what you need.
Quick Reply: A minor delay........
