no top end?
Old 04-20-2008, 06:58 PM
johnMZ24's Avatar
johnMZ24
johnMZ24 is offline
Default no top end?
hey guys, again another question for yas.. k, my neon has no top end now, it did like a month ago right after 4 grand it starts to haul ***, and now, again its juss goin real slow ta get up there nemore.. any ideas what it can be? its a dohc and 5 speed. i cleaned out fuel tank, ran higher octain, the cats gutted, no exhaust leaks, new iac and tps, cleaned the air filter,new fuel filter, new plugs and wired and coil packnew map sensor also... plz help!
Old 04-20-2008, 07:47 PM
Ghost Neon 2's Avatar
Ghost Neon 2
Ghost Neon 2 is offline
Default RE: no top end?
What mods do you have, and what (if any) has been done to you neon? On a whim, I'd say your car needs a tune up. New plugs, oil change, pcv, check tire pressure, and I am sure your intake manidold is filthy on the inside thanks to the EGR.
Old 04-20-2008, 08:00 PM
johnMZ24's Avatar
johnMZ24
johnMZ24 is offline
nope intake is clean as a whistle, and new plugs and fuel pump and filter and wires are all replaced.... it juss doesnt have power after 4 grand anymore.. i mean it use ta pullll like a sob but now it dont... and no mods juss real cai and exhaust
Old 04-20-2008, 08:59 PM
12 volt's Avatar
12 volt
12 volt is offline
sometimes takingout catcan harm your O2 sensor
Old 04-20-2008, 10:40 PM
spudsterier's Avatar
spudsterier
spudsterier is offline
is there a check engine light on???
maybe the timing jumped a tooth.....does it start and idle fine???
Old 04-20-2008, 11:44 PM
johnMZ24's Avatar
johnMZ24
johnMZ24 is offline
i had my computer scaned and it said 02 sensor bank 1 sensor 2, but thats the one after the cat and i had that disconnected but i didnt think that one really did anything.. but other then that i didnt have no other codes juss that
Old 04-21-2008, 09:33 AM
johnMZ24's Avatar
johnMZ24
johnMZ24 is offline
anybody wit ideas? plzzzz i need help fast and i cant figure it out
Old 04-22-2008, 12:42 AM
Ghost Neon 2
Reconnect your 02. There is no reason to just disconnect a sensor. Your PC sees a problem, so correct it.
Old 04-22-2008, 09:01 AM
spudsterier
when i was running a turbo on my car i had the downstream 02 sensor disconnected and it didnt give me any problems
Old 04-22-2008, 11:05 PM
johnMZ24's Avatar
johnMZ24
johnMZ24 is offline
its only when i floor it tho it dont got no ***** at past 4 grand, can it be my fuel injectors or sumtin?
