so what would be .. 2.4 to 2.0
na. the 2.4 cams are designed for low end torque. 2.0's for higher rpm power. this is because the stratus/caravan etc weigh more, and take more torque to move from a dead stop. neons are lighter, and therefor dont need as much low end torque for how chrysler wanted them to move.
2.4 cams will probably roast your tires even more, but lack in high end power. im pretty sure you can use a 2.4 intake cam and a 2.0 exhaust cam to get a little of both.
so your saying if i stuck with the 2.4 cams i could of had more torque.. well anyway i like how my car is the way it is but it would of been interesting to drive with the normal 2.4 cams then swap the 2.0 cams in and see the differance..
not more torque - just peak torque at a different place in the powerband. most likely it'd just let you spin your tires longer - not neccesarily make the car faster unless you made other mods - but you wouldnt have as much power in your upper rpms as you do with the 2.0 cams.
n like you said - ur already able to burn the tires pretty good.
to add - if jeremy helped you - im sure you have best setup with the parts you had.
