fuel regulator
Old 05-30-2008, 03:54 PM
Blockya's Avatar
Blockya
Blockya is offline
Default fuel regulator
Does anybody know the part# for the 58psi regulator for the plastic gas tanks from mopar performance???
Old 05-30-2008, 04:17 PM
12 volt's Avatar
12 volt
12 volt is offline
Default RE: fuel regulator
58psi regulator
isnt that the secondgen neonreg?
Old 05-30-2008, 04:27 PM
95to96transplantneon's Avatar
95to96transplantneon is offline
yes it it... however some people use them for 2.4 swaps and turbo aplications...
My question block ya is what are your plans... the 58psi regulator is only to be used in certain cirumstances, with certain set-ups...
Old 05-30-2008, 11:15 PM
I_Ride_Neon's Avatar
I_Ride_Neon
I_Ride_Neon is offline
Yea I thought he was boosting? That requires a rrfpr. 58psi is no where near enough for a boosted engine. I think the best option for anyone wanting more fuel is just a cheap adjustable fpr. Cost you $20 for it and about $15 for hoses and fittings to run a return line. Then you can adjust it at any psi you want. To do that you will need to bypass your stock regulator.
Old 05-30-2008, 11:40 PM
Thats why i asked him what he was acually doing...
So i could guide him in the right direction...
but he is right...
Old 05-31-2008, 09:29 AM
spudsterier's Avatar
spudsterier
spudsterier is offline
ORIGINAL: I_Ride_Neon
never never never go cheap when it comes to fuel systems.....unless you like having problems
Old 05-31-2008, 10:19 PM
Blockya's Avatar
Blockya
Blockya is offline
So true so true yea was tryung to avoid the spool mod but looks like I have no choice in the matter got a good self adjusting fmu regulator on the way and am going to go ahead with the walboro pump that way i can pretty much do what i want
thanks guys for the input!!
Old 05-31-2008, 10:21 PM
are you getting a adjustable fuel pressure regulator or a rasing rate fuel pressure regulator...
It seems as if your going turbo...
Post a pic of what your buying... you need a rasing rate fuel pressure regulator... not just a fpr...
Old 05-31-2008, 10:23 PM
Blockya's Avatar
Blockya
Blockya is offline
I have a fully built block with 8.8 pistons h-beams, cams, throttle body, srt-4 turbo setup, fidanza clutch and flywheel, quaffe LSD, all i really have left to finish is the fuel system but with summer here and the kids out of school the money runs a little thin for a few months so was trying to get the car on the road then upgrade the fuel as i could piece by piece.
Old 05-31-2008, 10:25 PM
Blockya's Avatar
Blockya
Blockya is offline
was looking at the rrfpr reg at modern performance it looks like a pretty good one
Quick Reply: fuel regulator
