Valve work: Do you have it
Old Jun 16, 2008 | 10:54 PM
Ghost Neon 2's Avatar
Ghost Neon 2
Default Valve work: Do you have it
Just sitting here polishing exhaust valves, and got to wondering about you guys/gals. Do you have valve work planned, or are you going to include it in your setup?
To those with valve work, do you have pics? How does this effect your engine performance, if anything?
Old Jun 17, 2008 | 01:56 AM
12 volt's Avatar
12 volt
Default RE: Valve work: Do you have it
you must be talking about angles on the valve seats.ive gone crazy at school with this stuff from 3 angle to 7 angle grinds. It really doesnt makea difference, bigger valve would be the ticket tho.
Old Jun 17, 2008 | 02:47 AM
95to96transplantneon's Avatar
I've also heard of doing a swirl pattern on the valves whats that about 12 volt???
Old Jun 17, 2008 | 02:48 PM
12 volt's Avatar
12 volt
i did valve workon 22R/21R heads whitch the 22had a swirl in the combustion chamber. Butthesewere more for emissinons and werent good for power. Ive never messed with swril valves so i would be able to give you a strate answer on that.
i guess swril valve would be more a Tuliped shape? Anyone gotapic of a swirl valve?
As for the valve seats best advice i could give is to follow the FSM.
Old Jun 18, 2008 | 12:20 AM
Ghost Neon 2
Anyone seen this before:
This is what Mike told me to do on my valves. Keeps liquid fuel out of the combustion chamber, if I recall correctly. The vapor increases combustion temps upping the power some and mpg's.
http://www.allpar.com/fix/holler/valve-prepping.html
Old Jun 18, 2008 | 12:41 AM
12 volt's Avatar
12 volt
still if your fuel metering system is working correctly atomization should have occerd by that point.
i would be afriad of doing it wrong and making the valve weak or adding spots for preignition
Old Jun 18, 2008 | 12:47 AM
Ghost Neon 2
Would you believe he has been making these for years? I made mine, and should have them in the head this weekend. Still need a higher flowing exhaust, but it will be running. Back-cutting valves is pretty commom, as are the grooves actually. Old way of doing things.
Old Jun 18, 2008 | 12:50 AM
12 volt's Avatar
12 volt
exhaust too?
Old Jun 18, 2008 | 12:57 AM
Ghost Neon 2
What are you asking exactly?
Old Jun 18, 2008 | 01:20 AM
12 volt's Avatar
12 volt
does the exhaust valve have the same thing done?
