centre console
there are neon center consoles without arm rests?
convert to a second gen console out of a junk yard. its pretty easy (grab the e-brake lever/bracket too)
gives you an extracup holder where that useless dust collecting spot is under ur e-brake and makes the top of the arm rest fold back to give the rear passengers at least 1 cup holder.
Trending Topics
ive been looking into this for my daily driver with the 2nd gen swap
if you want to do it, get a second gen console, and ebrake handle/bracket assembly, and some longer screws (i believe 1.5" to 2" not sure)
you only have to cut if you plan on using your stock first gen ebrake, if you use the second gen its offset and fits perfect
if you use the first gen shifter boot, it will leave a gap at the back, but its about 1/16" gap, nothing you'll notice without looking for it, if you can get the second gen shifter boot, get it it matches perfect
