tranny question
Old 08-16-2008, 07:11 PM
streetracer88's Avatar
streetracer88
streetracer88 is offline
Default tranny question
I was wondering if i can do a swap from my 3 spd auto to a 5spd auto seeing how they are the same engine will this work?
Old 08-16-2008, 09:40 PM
neonracer1010's Avatar
neonracer1010
neonracer1010 is offline
yes you just need all the tranny stuff and a different pcm
Old 08-16-2008, 10:32 PM
das2123's Avatar
das2123
das2123 is offline
Old 08-17-2008, 12:33 AM
TOOSTUBBORN2FAIL's Avatar
TOOSTUBBORN2FAIL
TOOSTUBBORN2FAIL is offline
its not that bad of a swap, just make sure of one thing
if you live in california, and its a auto sohc, dont do it, its illegal
trust my $3000 mistake (spent way more then needed, but its quaife'd and rebuilt, with aluminum flywheel and kevlar clutch)
california wont let me register it now
Old 08-17-2008, 01:01 AM
neonracer1010
cant u put it back stock and then register it n then re swap it???
Old 08-17-2008, 12:50 PM
streetracer88
ok thanks
Old 08-17-2008, 09:18 PM
TOOSTUBBORN2FAIL
you could swap back and forth if you wanted, smog is once every 2 years, the computer is the real drawback, it has to be scanned to the odometer mileage, which means you would have to have the atx computer rescanned at the dealer every year that you swapped, which is $100 a pop here.
for me wasnt really an option, the auto was dead in my car, dead dead, it was an old state forest ranger car and they abused the crap out of it
Old 08-17-2008, 11:06 PM
neonracer1010
well stubborn couldnt you like rite down the millage that ur odo is at on the pcm before u swap it out and then just change the millage in the car itself?
Old 08-18-2008, 08:05 AM
das2123's Avatar
das2123
das2123 is offline
PCM's don't store mileage on the neon though.
Old 08-18-2008, 10:52 PM
TOOSTUBBORN2FAIL
well, california smog goes in these steps
1 - inspect the car for anything that doesnt look right
2 - hook the car up to the computer, make sure everythings right (computer has info on whether is mtx or atx, dohc or sohc, mileage, error codes, what systems are ready to be checked (MIL codes)). If you read the directions in the mopar pcm, it shows that the computer has to be programmed by a dealer to match the vin and mileage or it will not pass in cali
3 - sniffer test at 15 and 25 mph on a chassis dyno
4 - gas cap check
Quick Reply: tranny question
