Road Race cam timing suggestions
Got a 95 Dodge neon and i'm tryin to figure out the best Cam Gear Timing...this is what i got...
Bored .50 over
12.1:1 JE Pistons
Forged H Beam Connecting Rods
Molly Rings
MSD Ignition system
Solid Core Plug wires
Comp Cams Stage 3 Extreme Road/Drag Cam
Crane Cams Valve Springs
Adjustable Cam Gear
Ported Head
Custom Intake Manifold
60mm Throttle Body
Mid Tube 4-2-1 Headders
Straightpipe to High Flow Straight thru muffler.
EGR Blockoff Plate
Mopar Performance ECM
UR Underdrive Pully
Solid Motor Mounts
Comp Clutch Stage 5 Sprung Clutch & Lightweight Flywheel
Any good tuning hints would be appreciated
Bored .50 over
12.1:1 JE Pistons
Molly Rings
MSD Ignition system
Adjustable Cam Gear
Ported Head
60mm Throttle Body
EGR Blockoff Plate
UR Underdrive Pully
Solid Motor Mounts
SOHC
www.ModernPerformance.com has the pistons. they specialize in Dodge Neon performance parts.
Use Molly rings and have the cylinders honed w/ 400 grit ball hone. that will give u the best ring performance.
I got the cam from NOPI about 4 years ago...they don't sell it anymore. Comp Cams.
SOHC
well yeah i modern sells some but not for engines that have the cylinders bored over a half inch. kinda seems like its not possible to take that much out and still have a cylinder wall.
From the pics i dont really see whats custom about the intake main.
did you make the exhaust manifold? any pics of that?
those pics are over a year old. I've spent a lot of time macining an aluminum intake manifold...I took half the runners that run to the head and welded them to an 8" aluminum cylinder. That made it easy to hook up the injectors. Made a place for the throttle body to bolt up on the side so i can run a cold air under the battery box w/o relocating it. and welded nuts on the inside for my sensors.
Trending Topics
